Recently, people have been going one of 2 routes with automatics.
First is to convert to manual.. easy to do as there are plenty of party lying around the import yards.
The other option is to beef up the auto slushbox and love it for what it is!
That's what this thread is about...
NO automatic haters
NO more wondering the potential of the automatic
So what i propose is that everyone with an automatic skyline post up your dyno figures and real 1/4 times (not g-tech figures!) and i'll collaborate the figures into the first post as much as i can... that way we can have an overview of how the auto stands on the track and what power is required to make different times..
Finally somewhere to compare auto figures, as most things you will see on SAU are for manual cars and don't 100% correlate with automatics...
So here we go:
rb20 - R31, R32, or cefiro.. stock = 100rwkw
DYNO
185rwkw - RB120WHY
179rwkw - AnFz
170rwkw - WazR32GTSt
165rwkw - RSTME
139rwkw - Nizmo_freek
1/4
11.08 @ 113mph - RB120WHY (with slicks)
14.6 @ 98mph - WazR32GTSt
15.0 @ 108mph - AnFz
rb25 - R33, R34, or Stagea..stock = 135rwkw
DYNO
317rwkw - dangerman4
255rwkw - Abo_Bob
244rwkw - lukits01
229rwkw - wildr33gtst
229rwkw - DivHunter
225rwkw - satantic
220rwkw - 4door_sleeper
203rwkw - pkblade
203rwkw - SECUR1TY
193rwkw - judd33
187rwkw - Haines
185rwkw - MacGuyver
181rwkw - Fly_with_sky
176rwkw - 666DAN
166rwkw - so_tred
160awkw - Tangles
160awkw - AlexCim
146rwkw - Basti
142rwkw - Howie
1/4
12.3 @ 113mph - Fastrotor
12.7 @ 106mph - Abo_Bob
13.0 @ 105mph- 4door_sleeper
13.0 @ ??mph - lukits01
13.5 @ 164km/h - judd33
13.7 @ 101mph - Haines
13.8 @ 101mph - SECUR1TY
14.2 - Alexcim
Hopefully a moderator can sticky this and it can be kept as a valuable resource and i will try to update weekly or even more often
Please try to refrain from general chit-chat, but feel free to discuss engine, suspension ,and trans mods that have been made to make the above times and figures ;)
cheers,
Warren
PS.. the only rules are:
- must be a nissan transmission
- must be original displacement motor
(basically an original car but modified..)
Edited by WazR32GTSt
https://www.sau.com.au/forums/topic/131489-the-automatic-performance-thread/
We kinda have one :P
http://www.skylinesaustralia.com/forums/in...showtopic=91916
Maybe ask buster to include "transmission" type into his format thingy?
As i know the cars on there are a mix of auto and manual
Ash,
i have a few isseus with that thread...
1) never updated
2) contains manual and auto figures
3) hard to find
i really want to separate the automatics and have a thread devoted to the slushbox so that all information can be correlated without bias
i have an auto and yes there is potential trust me i out run manual skylines with even afew mods while i'm running pretty much stock but as i'm not looking at big power n fast times i will be converting to manual becoz i miss the clutch lol...
any1 looking at fast times dont let the name auto fool u trust me u can get very fast times with autos
Heres my old cars results,i never got the chance to dyno it after the gtr fuel pump, R.I.P.S intake plenum and greddy profec B specII set to 13psi so i dont know what it wouldve been after those mods, have since sold it and bought a "MANUAL" r33 gts25t lol, the r32 went pretty good for an auto actually
1989 r32 gtst auto
standard everything apart from:
2.5"slipt dump pipe
full 3" exhaust
cheap as pod filter (no cold airbox or heatsheild)
600x300x76 FMIC with 2.5" piping
stock boost (11.2psi then drops to 9.2psi after 3500rpm)
139.7rwkw
No track available near Adelaide atm - so no 1/4mile times
Stagea RS V Four, 86500kms, automatic, RB25DET engine, Attessa 4wd
New Oxygen sensor & New 400amp battery
Davies Craig automatic transmission oil cooler upgrade kit
Whiteline front and rear adjustable swaybars
Whiteline front castor kit
Whiteline rear subframe alignment kit
Bilstein front and rear suspension shocks, with ‘lowering’ circlips, using standard springs
Maltech front and rear stainless steel braided brake lines
DBA slotted front rotors
Bosch 040 fuel pump with direct battery feed at 13.8volts
Nismo adjustable fuel pressure regulator
Nissan Z32 Air Flow Meter
3inch JustJap stainless steel single dump pipe system
3inch Catco high flow catalytic converter
3inch Dayz edition(?) cat-back exhaust system with quiet muffler
K&N pod filter
Cold Air Induction box with direct air feed
Hybrid dual stage Electronic Boost Controller, set to 10 & 12psi
Apexi 'hybrid' front mount intercooler with custom dodgybrothers pipe kit
Apexi boost gauge
Apexi SAFC Super Air Fuel Computer
Apexi SITC Super Ignition Timing Computer
R34 GTT 17inch rims
Hankook K104 tyres, 235/45/17
160 all wheel KW @ 12psi
Soon to be added, most likely towards the end of the year:
MV Automatics auto transmission valve body upgrade
Hiflow turbocharger and a dyno retune, at 1bar
Expect 200 all wheel KW at 15psi - dont know what sort of 1/4 mile time that'd produce, probably 14's due to the weight of the Stagea.
:D Brendan
Edited by Tangles
keep those figures coming guys!
don't forget to sepcifically mention if you have any work done to your atuo as well as any engine mods
i personalyl have done to my trans:
- 2800rpm high-stall
- stage 2 shift kit
- trans cooler
although the first 2 were not in when i recorded the above figures..
I ran 15.01 @ 108mph. 60 ft was 3.0+. Very hard to get any wheel spin / momentum of the line
Car was making 179rwkw (untuned)
HR31 GTS-X
RB20DET Silvertop conversion
GT2871r @ 15psi
Walbro fuel pump
FMIC
Pod and steel intake
Adjustable fuel regulator
Auto is a VLT box with a foward pattern manual valve body with strengthened kevlar bands and planetary housing and gears....courtesy of KEAS
I don't think you ran 108mph mate.
I have run 12.7 @ 106 with 255rwkw.
I suspect that for some time now I have been getting more power on the dyno than on the road because I think a restriction is created once I lower my bonnet.
Auto has been fully rebuilt by Mike at MV Automatics in Adelaide. Uprated valvebody, kevlar bits and bigger servo's etc etc. Stall caonvertor is something like 1800 but the flash speed is the same as the stall speed. Normally the flash speed is lower.
Stock auto, panel filter, full zorst, 12psi
Same mods plus Powerplay ROM tune:
New tune, 480cc injectors, GCG highflow turbo, FMIC, blew the auto transmission at this point:
The engine was then rebuilt with Tomei type b Poncams and the below 255/256 dyno sheets are for this stage.
Timeslip
UAS dyno run 256rwkw
Bel Garage dyno run 255rwkw (same mods as UAS one)
Then I converted to manual for a bit of fun.
I think I know what I ran. But having said that, perhaps I could say that you dont have a true 255rwkw. 1/4 mile times, dyno figures...they are all things we can measure, but sure as hell sometimes they cannot be accurate 100% of the time
I would say that my dyno reading is slightly low, as duty cycle on the injectors was reaching its limits as was the AFM...so I would expect peak power to be slightly higher.
Also I presume you have an RB25...your dyno graph shows a lot more power down low compared to how my turbo setup responds. I'll try to get a scan of mine up to show you what I mean :)
It pulls like a steam train in 2nd and 3rd....all power made medium to top end.
At a recent drag day, I was reeling in rexies mid track that were making 13sec passes. I always ran out of track though (800m might tell an interesting story!). So that figure I believe to be more or less accurate.
Abo Bob's problem is the dead spot between 3,250 rpm and 4,500 rpm, as can be seen in the UAS dyno graph. It is killing his ET and TS, hence not representative of his true 256 rwkw potential.
:P cheers :P
Sorry mate didn't mean to be offensive. I just meant that 108mph sounded about 8-10mph too fast for the ET and power.
I might add that I'm hopeless at the quarter mile. Always have been.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
