  • Replies 44
They're called Drift-tek or some limp wristed shit like that, around $350 a pop or something like that, and fit under GTSt's perfectly. Available in 17x8, 17x9, 17x9.5 in Gold, or Silver.
www.koyawheels.com lists the contact details.
They're not 18's but they're cheap cast rubbish that look decent, I might get a set for my car just so I don't worry about scratching up the SSR's during regular road use... they're cheap enough.
IMHO they're the new Impuls... every teenager's goin for the "OMG DISHHHHH" look with the impuls or "OMG DRIFTTTTTTZOR" look with these things.
But hang on...arent Bee-R just crappy cast rip offs of Nismo/Rays LM GT4S?
Hell even the LM arent as light as my WEDSPORT rims...
Meh, if anyone wants a set of 17" LM GT4s for an R32 GTST i want to sell mine...i feel ill when i look at them now, and have found somehting i like much better :D
LMGT4s are such a terribly ugly wheel :D , I will help you out and give you $50 for the set Troy.
Always happy to help a brother out
$50 , only because i dont like them doesnt mean i have too much money :D
Its a bit like when you were a kid and you bought a tops BMX, then the kid you dont like down the street raves about your bike and buys one...you hat ehte fact that your the same simple minded fool and run off to find the next piece of automotive botox that defines you as a car enthusiast...totally farked up but sadly the way i think :D
I can't believe there's ever gonna be a need to show one upmanship when you live with a guy who drives a Lada.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
