  • Replies 44
They're called Drift-tek or some limp wristed shit like that, around $350 a pop or something like that, and fit under GTSt's perfectly. Available in 17x8, 17x9, 17x9.5 in Gold, or Silver.
www.koyawheels.com lists the contact details.
They're not 18's but they're cheap cast rubbish that look decent, I might get a set for my car just so I don't worry about scratching up the SSR's during regular road use... they're cheap enough.
IMHO they're the new Impuls... every teenager's goin for the "OMG DISHHHHH" look with the impuls or "OMG DRIFTTTTTTZOR" look with these things.
But hang on...arent Bee-R just crappy cast rip offs of Nismo/Rays LM GT4S?
Hell even the LM arent as light as my WEDSPORT rims...
Meh, if anyone wants a set of 17" LM GT4s for an R32 GTST i want to sell mine...i feel ill when i look at them now, and have found somehting i like much better :D
LMGT4s are such a terribly ugly wheel :D , I will help you out and give you $50 for the set Troy.
Always happy to help a brother out
$50 , only because i dont like them doesnt mean i have too much money :D
Its a bit like when you were a kid and you bought a tops BMX, then the kid you dont like down the street raves about your bike and buys one...you hat ehte fact that your the same simple minded fool and run off to find the next piece of automotive botox that defines you as a car enthusiast...totally farked up but sadly the way i think :D
I can't believe there's ever gonna be a need to show one upmanship when you live with a guy who drives a Lada.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
