Hey guys...
Duncan and I were talking about this the other night on the way home from the Hunter... and we don't know what he does. the following poll may contain what dino does... and it may not. have a guess anyway... at this stage there are no prizes for guessing... but if people want to donate then we might be able to get something going!!!
goodluck.
  • Replies 55
Me thinks he's a secret agent working for holden. He's always cool and clam, and everytime I see him he's wearing sunnies.
At the last track day he had a camera and was taking surveillance photo's, probably trying to asses how the new commies will matchup against the gtr's.
He's now infiltrated the skylines forum and is a mod! I think he's got his eyes me now..... *hides under desk*
He could be a spy who's involved in shipping uranium to McDonalds to improve the taste of the burgers.
He could also be a spy who's apart of the FIA board, and is master-minding the collapse of F1. Manufactures are threatening to start their own series cause they're not happy with Ernie Eccalstone's control of F1! There you go! :P
Or he could be shipping uranium to BMW to power the engines in F1. How do you explain that BMW have the most powerful engine, yet they've only been in F1 for a short period of time. Maybe the uranium is used as a fuel source and the depleted unranium is used in the engine to make it rev to 19,000 rpm.
I know what he does, but I'll just stir him up. :D
only 4 more days till dino comes back... I wonder if he has internet access on his mission to south africa?
Maybe he is too deep under cover.
Don't BWM have a test facility in South Africa... or was that Holden?
Or maybe the cover he is under is the one found on a bed?
Looks like no one really knows... but that he sells his body on the corner is the most likely!
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
