  • Replies 51
Posted Images
i think he his plan is that by removing the aircon he can run shorter cooler pipes so he has better throttle response.
what you have to take into consideration is that if you have the cooler pipes too short you tighten the bends, which makes the air have to change direction more suddenly. if that pic is of the setup ypu are trying to shorten, then there isn't much you can do before you start compromising air speed.
another option would be to fit a smaller cooler. removing 6 inches of cooler will reduce the air volume by more than removing 6 inches of piping.
How do you plan to achieve throttle response? Stop being so secretive :D
Not being secretive.
Untimately the aim is to keep the intercooler piping as short as possible and with as little bends as possible.
We can play around with intercooler sizes, end tank designs... the sky is the limit.
At the same time using chinese factories to keep the prices down but keep quality up to a good level (as seen with the bar and plate cores that people are using in 400+ rwkw cars).
We recently did a project for the VL guys which can be seen here: http://www.calaisturbo.com.au/showthread.php?t=78364 (the aim of that project was to keep the intercooler hidden aswell as avoiding any holes being cut in the chassis)
Greg
Edited by EXAUNV
I'm not talking about losing the aircon due to the power loss. I'm talking about losing the aircon for space in the engine bay/front of the car.
dude, SR20 is GIVING you room if your not using an RB20.
room should be your friend.
Keep the aircon - or suffer in the heat (in silence) :D
300rwkw - never going to get rid of my aircon. I dont care what i have to do
And if you notice a throttle difference with an extra bend or two, i'll hand you a medal ;)
Cause you wont notice it at all IMO.
You think that there wont be a noticable difference going from a Hyrbid style intercooler kit to the one I'm using in my R32? (or any other cooler kit that's remotely similiar)
I'm not talking about making kits for an SR in the skyline range as there is clearly enough room (as seen in my R32), but I'm asking to see how many people are actually using their aircon and how many people would lose it for a setup like this.
With the SR range of cars, it's not necessary to lose your air con.
Greg
Edited by EXAUNV
umm. the ac compressor turns of at any major load any way :D
just the extra heat through the radiator youve gotta wory about. its gives NO LOSS OF POWER at all.
so just bask in the nice chilled enviroment lol
We're not talking in terms of power loss from the AC compressor.
We're talking in terms of space in the engine bay.
Greg
do a search for some of the many posts by sydneykid regarding shorter cooler pipes and how removing 20cm of pipe is going to make no difference, but to do the maths
at 3000 rpm and zero boost / vac your 2.5L engine is consuming 3750L of air per minute or 62.5L per second
assuming u save 20cm of pipe and that its 2.5inch pipe that will have a volume of approx. 1.5L in that pipe.
so your engine will consume that air in 0.024 of a second, now add boost etc....to the equation and is it worth sacrificing your aircon for 0.024s of throttle response
sorry if this is wrong but as my understanding goes this is how it'd work
20cm's of pipe?
You'll be losing around 2 meters, aswell as around 600+ degrees worth of bends.
Thats still only .2 seconds
In theory, pollsibly...
One of the drift cars we used to sponsor (180/s15 front) had a FMIC install, it's now running a V mount setup and the difference in throttle response is incredible!! I can't time it, but you sure can feel the difference.
If the RB guys aren't interested in these sorts of kits, that's not a problem. We'll just make them for the SR's.
Greg
I don't understand the concept of a vmount setup?
Any crude diagrams or picture examples?
What I really want though... :)
An FMIC setup that uses the std piping route. I would like an fmic to fill the whole front bar inlet as to let as much as possible air pass through to the radiator.
Currently as can be seen the end tanks block of a considerable amount of the front bar.
The core i'm using is apparently a spearco bar/plate core 450x260x90 *from memory* with sligh off centrally located inlet/outlets. being center located makes it easy for the hot fmic inlet pipe to do a 2 x 90 degree turns to enter the fmic (drivers side). It runs crappy 2.25" piping. :)
The core i'm using is apparently a spearco bar/plate core 450x260x90 *from memory* with sligh off centrally located inlet/outlets. being center located makes it easy for the hot fmic inlet pipe to do a 2 x 90 degree turns to enter the fmic (drivers side). It runs crappy 2.25" piping. :(
I don't have any pictures handy, but the overall idea is to have the radiator sitting on a 45 degree angle and your intercooler sitting on a 45 degree angle, the overall the advantage is that the pipes are shorter, and neither your intercooler or radiator are getting less air flow. The disadvantage to this setup is heat soak.
Greg
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
