Blah Blah Blah
Let me guess, you didnt bother to go back to them or call them and give them the chance to resolve the problems?
Regarding your boost issue, obviously UAS had a concern about putting any more boost through your engine - would you have preferred them to just wind it up anyway and run the risk of possible engine damage? Come on
mate if you had got your car done with me and there was a problem i would hope you would bring it back so we could sort out the problem because if you didnt and then started talking shit about my workers they would track you down and give you some shit so you should watch what you say i sure john would have taken another look at it for you if you had of given him the chance
I should hope your post isnt directed at me Jason, you might want to watch who you quote in your posts :)
Hey everyone i wasnt trying to stir shit, just adding my opinion on a workshop. I did speak to john in person about the problem. I wasnt happy, he wasnt happy and i told him then and there that i would never recommend UAS to anyone. Im surprised a newb to your forums could cause such a fuss people. :P
That's right - it's most likely because of the fact that you are new to these forums that you've only received a caution.
Put it this way, if someone uses these forums to say something negative against a business, that business could sue the forum OWNER for defamation, and if that happens the forums may well be shut down as a consequence, and then we ALL suffer... We've built up a good community, and in many cases a new network of friends both online and outside in the real world - lets help it stay that way.
Hey everyone i wasnt trying to stir shit, just adding my opinion on a workshop. I did speak to john in person about the problem. I wasnt happy, he wasnt happy and i told him then and there that i would never recommend UAS to anyone. Im surprised a newb to your forums could cause such a fuss people. :)
it doesn't really matter to me whether you were intentionally trying to stir shit or not. you posted up half a negative story and named a business. I've explained to you that it was against the rules. You either learn from this, or you do it again and I will come down on top of you like a 16 year old virgin on top of Angelina Jolie.
John being a business owner with a reputation that was hard earned and hard to protect has done the right thing and contacted you to see what your exact problem is. So if there is still some issue, then contact him back and resolve it. If not just accept it and move on. The very fact the he asked me to leave your (potentially damaging) comments on an open forum and actually wanted to resolve your problem should indicate to anyone that he owns a workshop worth using.
Anyway, let's all get past it shall we?
I don't have a problem with someone not recommending or warning others if genuine and preferably consistent poor service but not if exaggerated. Also if one person at a business as seems in this case a mechanic and years ago it seems then it does not mean that business is not good for ever more. I do not know who you are but I have sent a PM to Wateva to find out who and what and where years ago so I can at least see what happened or did not happen. Wateva you wonder why some are taking your post as aggressive or possibly over the top and not asked for anyway but rather where to go. If we were stealing form you or actually doing really bodgy work and did not want to do anything about it then different. It is so rare even though we do some very technical difficult work one can bank on some not understanding or taking things the wrong way or as mentioned can't be pleased. I can't comment on this case at all as I said I don't know who Wateva is or his car and years ago and probably a few thousand Skylines later. I know I always try and do the right thing by customer to the point where I regularly get handles but give customer the benefit of the doubt and warrant and cover costs I am sure few workshops would.
Tell us who you are or PM me with rego details and name and I look up what terrible thing we did.
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
