Question: Is redlining your car a good or bad way to drive it? Let me give the example by redlining I mean shifting at 7000 rpms. I have a 95 r33 gts-t and when i drive it the shifts between 1st and 2nd usually come at 5000 rpms, 2nd and 3rd 5000 rpms, 3rd and 4th 7000 rpms and 4th and 5th 7000rpms. I wanted to kno if this will affect my engine in a negative way. This is not everyday driving just when im in speed mode and want to remind my ride tht she still is a sports car. What do u think good or bad? All answers welcome.
https://www.sau.com.au/forums/topic/132577-for-the-experts/
well..as long as u dont do it often it should be ok....
and by the sounds of things, you should be doing about 180 on 4th - 5th - so perhaps take it to the track.....
You are absolutely correct by 4th doing about 5 or 6000rpm the speedometer is maxed out so by 5th it doesnt eve make sense lookin at the speedometer. So does tht mean the cars top speed cannot be measuredby the stock speedometer if so wht is the max speed for a 95 gts-t completely stock.
https://www.sau.com.au/forums/topic/132577-for-the-experts/#findComment-2457766
Redlining at 7000 RPM = thrashing.
If you thrash your car, dont expect it to last as long.
I drive an auto, when driving normally I let go off the gas at around 2000 RPM... then go back up to 2000 RPM.
Also I never go over 2000 RPM when the car is warming up for the first 10 or so minutes...
https://www.sau.com.au/forums/topic/132577-for-the-experts/#findComment-2457779
I personally think you're a dipshit, with no regards to other peoples safety :). If you want to do such speeds take it to the track, or any other legal motorsport.
Mods please close and remove this topic :laugh:
https://www.sau.com.au/forums/topic/132577-for-the-experts/#findComment-2458533
Agreed..
We are going to see more and more of these incidents/posts as the R33's are becoming dirt cheap now. Affordable for young P platers and the like.
https://www.sau.com.au/forums/topic/132577-for-the-experts/#findComment-2458613
its a sports car, and hence it can withstand some redlining - but not all the time. And as the others have said (and as I mentioned), if your ever in the mood to go sick with the speeds - tracks are the best option man. I admit, I am very tempted to take the car to its limits - but not on the roads. I live in Mt waverley (vic) and the traffic here is quite intense - very easy for someone to have a crash get hurt or even die...
So - after all that, if u feel the need for speed - track or drag strip.....
https://www.sau.com.au/forums/topic/132577-for-the-experts/#findComment-2458632
Hmmm redline? Meaning possible failure and crash increase, hmmm i think someone will come unstuck oneday, and should keep there redlining to the tracks and off the road.
But O/T you should treat your car better than that, just becoz you can do it now and then, doesnt mean sh!t, Your just putting other people including yourself at risk, so aggreed this topic is sorta pointless and should be closed as sending the wrong message to others out there i think?
https://www.sau.com.au/forums/topic/132577-for-the-experts/#findComment-2458757
i agree with most of you on here that high speeds should be kept to the track.
as paulr33 said redlining is pointless in a stock r33 as peak power is 6400rpm or so from memory
having said that high speeds should be kept to the track if that situation was right on an open road with no trafic where speed limit is 100 i would probly take it to 160 if it seemed fairly safe, any thing over 160 is rediculus on public roads.
https://www.sau.com.au/forums/topic/132577-for-the-experts/#findComment-2472024
Agreed..
It is for the tracks maybe you should ask b4 assuming. And to Al F%$K off you dont kno me asshole.
https://www.sau.com.au/forums/topic/132577-for-the-experts/#findComment-2475211
....................... 3rd and 4th 7000 rpms and 4th and 5th 7000rpms. I wanted to kno if this will affect my engine in a negative way. This is not everyday driving just when im in speed mode and want to remind my ride tht she still is a sports car.
Please explain this, or are you now changing your story :O. That phrase implies that you are doing this on the street. I may not know you but i have only replied to what you wrote, thus you are a FOOL!
https://www.sau.com.au/forums/topic/132577-for-the-experts/#findComment-2475660
babied hard.
Usually until its warmed up I just make sure the car stays off boost. I usually like to rev it up to about 3gran (off boost). Keeping it below 2000RPM usually puts the motor under more load which i assume is bad for a cold engine
https://www.sau.com.au/forums/topic/132577-for-the-experts/#findComment-2503983
babied hard.
Its not bad for the motor unless your in top gear trying to lug it out of a corner with the motor clearly labouring.
Select the correct gear for the road speed and it will be perfectly fine.
https://www.sau.com.au/forums/topic/132577-for-the-experts/#findComment-2504110
    • I am well aware as I did rant at him to buy a MX5, buy the 2.5 before he DIY'ed it, etc as well as do things to the holden. He will obtain a ND. It's the best of both worlds. They look great in person, definitely the best looking one. Just a matter of time now.
    • Remember this is the same person who said he’d never own an nc
    • ouch! how is the car now?I had sold my gtr but have been looking into some on trademe and a 260RS but I wouldnt be keen on any repairs needed on them
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
