  • Replies 60
Posted Images
This is all quite old news, it happened months ago. It was (7.81 @ 17xmph) the first meet with a new engine and turbo setup - the package definately had more in it, and has not done a meet since. I fully expect this car to go quicker than HKS did in Oz....
I recommend going to watch this - seeing/hearing it go in person is definately a hoot :P Theres no other GTR in the world currently racing that I am aware of which is going to show you solid 7 second runs.
Awesome!!!! gives me goose bumps!!!
I have to ask a question, well a couple actually.
Is this 7sec GTR rear wheel drive?? what's the go?? no smoke or spinning from the front wheels??
which prompts me to ask another question?? i've watched a few drift videos & see some GTR's drifting & only smoke from the rear??
WTF? am i missing something??
You can convert them to rwd in the 32s by pulling a fuse. R32s Im pretty sure are primarily RWD until you loose traction as well.
Hmm, mines only an 11 sec GTR & when i jump off the clutch at 8,000 i'm smokin 4 x 4 :D
i reckon he's gotta be an 11,000 man so it should be smoking from every orifice!!!
awesome car, just f ing awesome!!
would really like to know the answer as to why the Mecca of 4WD weaponry is running 7's on two??
whats the benifit?
two on street tires would be a saussage sizzle?
Drag slicks different of course, but just doesen't compute?
Most likely converting it to rear wheel drive for the burn out to heat up the tyres.
Either way i think it would still be 4WD!
Quick times but since its on Menthanol now i don't really consider it in the same leauge as HKS, GTR 700 and Keir Wilson etc. those guys are all still using petrol which is where the challenge is at.
As you can see converting to Methanol has made it very easy to dipp into the 7's
I seriously think GTR 700 will be the 1st Aussie 7sec GTR if and when it comes back!
Sorry - It IS still running a 4WD setup, and also ran into the low 8s before it turned to Methanol. The Methanol setup was the major change which got it into the 7s, and since then its got a new motor and turbo combination - who knows what THAT evolution is capable of. He's taken it to Oz to find out :O
I'm guessing you guys know that in testing at Willowbank Heat Treatments have got down to 7.73 @ 183mph? They have a reputation of systematically getting quicker and quicker - so fingers crossed the weather is good for Jamboree! >_<
That'd be the quickest run ever by a Skyline GTR in Oz - quite cool when you consider the HKS drag R33 has raced there!
it still runs an air to air intercooler also last time i checked. why i dont know but there must be some need for cooling.
a local tuner here (blue evo that runs low 8's) has said these passes arent on full power either so that shows lots of promise :(
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
