hey guys, finally found my prob in racing my car, traction! i am now looking for some 16" micky thompson semi slicks for my car, if anyone has some that i can borrow :laugh: or if i could buy some that will be great.
Thanks, Phill
https://www.sau.com.au/forums/topic/132668-semi-slicks/
what for?
The street or to race at the track?
You dont need semi slicks, you just need to spend good money and get good tyres.
I had 243 rwkw in my R33 and ran 12.5 on 18 inch 265 Potenza 8000e. 1.8 Second 60 ft. Thats what most GTRs get with 4WD.
So many idiotic mates of mine always go and get slicks or semis, and there times are really average.
On the strip, If you have less than 300 rwkw in a skyline and need slicks, you just dont know how to drive
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2458448
best time was 13.3@105mph 1.9sec 60 footer on some runs.
starionturbo: the car has run 13.1@105 with 205/55/R16s baught second hand just to pass rwc. I dont need street tyres, i can run flat out slicks or mt radials.
2rismo: delivered to melb? how much per tyre roughly mate?
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2458571
what for?
glad someone said it :)
not having a go at LTHLRB...not at all. 205rwkw with no ECU or piggyback is a mad effort...but all these people using slicks to break the 12 sec barrier...I was always under the impression that slicks were when you were getting down to 11's and 10's....
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2459003
Personally I think that if you are drag racing, you should run semi's or full slicks. It's what the pro's do, and it shows the full potential in a time and MPH of your car's power.
Agreed. I was there on friday night at I ran a 13.43 with about 200-210 rwkw and my suspension setup is for drift/track. It's very stiff. I used semi slicks because I had them. Definitely helped. I'm no drag racer, just wanted to have some fun. Why not get some slicks. Easier than swapping or adjusting suspension...
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2460032
my suspension is stiff as anything, its more drift/track aswell. But i dont want to go making my ass end any softer because it will be shit for road. The car is making the power yes, thanks Dez for the compliments, thats about the most power i can get now is 209.5kw untill i get my pfc. But i haveto resort to slicks or semi slicks to get me into the 12s with a completely std ecu/injectors/turbo.
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2461631
If you're making over 200rwkw you DO NOT NEED semis/slicks/drag radials/whatever you want to call them. What you need is practice.
12.799 @ 107mph on Falken ZE326 buckets of crap with only 190kW.
Adrian
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2461868
Adrian
What suspension setup did the car have?
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2462489
got a quote on mt semi slicks, for the normal ones 255 x 16 its 280 or so and the others (discoloured) are 240, they had to use more powder to break it out of the mould, and the tyre is completely white PIMP STYLE. Does anyone know if that will effect the performance of the tyre?
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2468026
It will absolutely NOT affect the performance of the tyre. The factory seconds stock from Rocket is 100% guaranteed and warranted against defect (other than cosmetic, obviously).
Yes I'm going auto.
LTHLRB, I still reckon you should call Stuart @ Bezerkly Automotive and ask for a price - 02 42261888
Adrian
https://www.sau.com.au/forums/topic/132668-semi-slicks/#findComment-2468291
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
