  • Replies 59
someone that owns an Nissan 350Z Tourer.
You wont find anyone here...
Maby try the 'Z' Club...
On a side note: Personally i get a little anoyed at some ppq plates. I mean in terms of combinations that make no sence and people say its this and you go arhhh... Then they try to sell them for stupid money when no one gets it??? END RANT
https://www.sau.com.au/forums/topic/132700-ppq/page/2/#findComment-2465955
i dont understand the explosion of personal plate buyers....dont you guys have something better to spend $400+ on (performance wise)?
PS:
yes it is ironic that someone who has personal plates is making criticism of them, but i only wear mine, as they were a surprise present from my wife. :laugh:
OBI-78
https://www.sau.com.au/forums/topic/132700-ppq/page/2/#findComment-2470965
Personally i think they add to the asthetics of the car... I was lucky to get NIS450 on my patrol when i got it... suits blacky very well... Its an individual thing.. each to there own... i personally think they look heaps better, make the car stand out and individualise it... But my car is kind of all about standing out... The only downside i see to them is that they are usually alot easier to remember and therefor if u do something wrong u may be more likely to suffer any kind of consequence someone may be willing to dish out.
https://www.sau.com.au/forums/topic/132700-ppq/page/2/#findComment-2472490
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
