I have been having a problem with flat spotting.
I run NGK plugs with a heat range of 7 and on cold canberra winter mornings they flat spot until I get some boost over them, then they are fine.
I have tried using a heat range of 6 and they dont flat spot in the morning but they do flat spot with higher boost levels and they also knock a little higher (I am guessing pre-ignition)...So I am sticking with the 7's gapped at .6
Anyway could this flat spotting be the reason why my catch can has fuel in it? The catch can does not feedback into the inlet and I have blocked the PCV valve.
Also does a smaller gap rob you of any power?
Any ideas on the matter would be great
thanks in advance.
Edited by GunMetalR33
https://www.sau.com.au/forums/topic/133164-petrol-in-the-catch-can/
  • Replies 44
too much knocking or something else has caused your rings to lose their tension and petrol is bypassing them and its going round with the oil.
That's what I figured but there is no oil in the catch can and the compression in all 6 cylinders is within 10% of each other. If the rings were worn it would show on the compression test and I would think there would be oil in the catch can???
yes, smaller gap will rob you of power. why are you gapping the plugs so tight? 0.6mm gap is tiny. you should be somewhere between 0.8mm and 1.0mm.
edit: I have NFI how you are getting fuel in your catch can, but it's not good. 2. are you sure it's fuel?
well the petrol thing isnt...we had a similar problem in our race rb25det except the rings were shagged and the compression was down, regardless if they were all down the same or within a certain amount it was still happening, petrol in the catch can, not just oil.
I cant see another way of it bypassing and getting into the catch can.
With such a smal gap, you are probably not burning the fuel properly. Unburnt fuel is then being dissolved in the oil on the cylinder walls and taken down into the sump.
Open the gap. (usinga really small gap is only masking the real problem)
compresion test with fuel washing away oil on the bore is not a acurate test, remoove the plugs + the fuel pump relay, crank the motor over and let all excess fuel out, then re oil the bore and potentialy change the engine all oil together, lightly lube the bores with small amounts of oil then allow the car to sit for a lil while then perform another compression test..
Thanks for all the replies.
To answer a few questions:
1)Yes I am sure its fuel, very little oil, only enough to slightly discolour the fuel.
2)I run .6 of gap to stop flat spotting. Anymore gap and it flat spots. However I have removed a big restriction in my zuast since gapping the plugs down so I might gap them out and see what happens.
3)The max compression in was 150 psi in one cyclinder with the rest being within 10%. Most above 140 psi.
Could it be a head gasket problem? I am running 19 psi :P (yea forgot to mention that)
PS => if the rings are worn which I am sure they are (at least a little) how long will they last. Will they continue to wear or will they just sh*t them selves one day :{
Also how much for a re-build with forgies if I take the engine out and deliver it??? Just after a ball park figure. I am tring to save for a house :{
having spoken with Timmy and hearing the power you are putting out with standard internals it would not surprise that it is starting to die. Standard internals + the power you are making = upcoming rebuild... sorry to say it :P
oh also forgot to mention alot of the SAU Canberra and even Sydney guys who have had rebuilds have gone and seen Greg @ proengines. Maybe give him a call he may be able to offer some advice. http://www.proengines.com.au/
having spoken with Timmy and hearing the power you are putting out with standard internals it would not surprise that it is starting to die. Standard internals + the power you are making = upcoming rebuild... sorry to say it :/
Yea, a lot of power to timmy is 140rwkw or what ever his old beamer used to make :mage: I have about 260 now and plenty of guys run that sort of power for a while. But I think you are right, engine is starting to get a little tired now :P
if hes only running the 246rwkw then stock internals are fine. As for 20psi and fuel in catch can also its missing.... What do all the plugs look like? If for some reason there is fuel in the oil look at the bigger picture your oil is f**ked now its thined out which will damage your bores.
I cant see how fuel gets into the oil, ie its sprayed into a chamber compressed then detenated and push out the exhaust valves.
You must have some bad underling problem eg craked head, head gasket to oil, valve guides, oil rings.
... I am running 19 psi :P (yea forgot to mention that)
There's the reason for your flatspot - the engine probably can't ingest air at 19 psi. Back the boost off a bit - I reckon 1 bar is more than enough.
I only just replaced the oil 1 month ago, I had 245rwkw before I shaved down a restricting turbo spacer to the correct diameter. Car is a lot faster now... I estimate about 260rwkw...
Plugs look good, a nice bronzy like colour but not too light...
So you reakon I should change the oil again? This motul stuff aint cheap :P
Yea, I will re-grap the plugs to .75 then wind down the boost till she stops flat spotting. Does anyone know the coversion between psi and bar, as in what is 17psi in bar?
If this is the case...maybe see if you can borrow a set of splitfires for a day and gap your plugs to .8. I still had major issues with those bosch coil packs (if you're still running them?) and haven't had a hint of a miss since I got the Splitfires
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
