I'm having problems bleeding the clutch on my R32 GTST. I've bled it so there's only clean fluid coming from all three nipples... no air... but there is still absolutely no pedal feel. Does anyone know whats going on??? :ninja:
https://www.sau.com.au/forums/topic/133213-clutch-bleeding-problems/
Well i'm guessing there's a lot of air in them as i've just done auto to manual conversion so all lines were installed with nothing in them.
What do you mean by "back off the master cylinder" ?
For your future reference aftermarket (Protec & PBR) clutch master cylinders and slave cylinders can be picked up for ~$70 and ~$40 respectively.
When bleeding the R32's clutch I start with the master cyl, then the center box and then the slave, then do it again.
I've had a few issues bleeding mine in the past so I removed the center box and length of lines. I simply bent the metal line that runs in to the box back 180degree's in to the rubber hose that runs to the slave cylinder. Works well and actually provided better clutch feel that makes driving a ceramic clutch just that little bit easier.
Some have suggested this center box and length of lines are there to help keep the clutch fluid cool. I'm not so sure; what temps does the clutch fluid really see? A half decent dot4 boiling point is ~250-270degree's, if fluid temp was really an issue they would have set up something similiar for brake lines that see much higher temps that a slave cylinder.
Hey Cubes, where from?? I'm having similar issues as Psymon!
Edited by manage13
U can get dud new replacements though, as i found out. I replaced my master and bled it but it still had a slow leak ( put your foot on the pedal resting and it would drop slowly)
If the tiniest bit of dirt gets in, it can fark the seals.
I did buy a set for one of the guys interstate and posted them out to him, so i may be able to do it again if ppl didnt mind paying for my time/petrol to organise clutch master/slaves from all clutch and brake here in SA :cool:
I got a IBS slave cylinder to fit an rb20 box and it was about $30 from a brakes place (any brakes / clutch place that can get IBS should be able to get it)..
http://www.skylinesaustralia.com/forums/in...slave+cylinder#
^^ All there
It's much easier to bleed if you spend $70 and get a one-piece braided clutch line as well to get rid of the twisty pipe.. then there is only two points to bleed.
Predator;
Instead of the braided clutch line I simply removed the centerbox and bent the line 180degree's in to the rubber hose that runs to the slave cylinder.
Works well and is free. :O
EDIT: Checked the link.. I've just repeated myself. lol
you can do that as well if you like :O when going from auto to manual you have to track down / buy the extra bendy pipe.. in my case was easier for me to order a new one.
Psymon I hope you don't mind me highjacking your thread for a little while but I have a similar problem to you. Hopefully someone can help.
I have been bleeding my clutch for the past two weekends for more than a few hours. Yet the pedal pressure increases slightly however when the car is started the pressure of the pedal drops a little. I can’t see any visible leaks from the slave and I believe I have got rid of all the air pockets as I have bled the clutch more than a few times now. Can anyone hazard a guess to what my problem is? Has my slave had it?
Thanking everyone in advance.
hmm OK I guess it might be GTR only...it has a vacuum line from the manifold to a small booster at the master cylinder. When the car starts the vacuum makes the clutch pedal noticably lighter.
Hi Duncan, thanks for the reply.
The clutch is much lighter when the car is running however I can't select gears. Also my clutch used to rattle when the clutch pedal was pressed down now I hear no rattle. Any idea??
Did you try bench bleeding the master cylinder?
Sometimes when you try bleed it in the car when the master cylinder is new, and you keep pumping it, the cups inside the master cylinder can turn inside out.
So when you bleed it fuid still comes out when the nipple is open, and when you close it and pump the pedal, it doesnt hold pressure and the piston just passes through.
    • You can’t see much on the other side as the lcd is there I don’t think it’s the same as the m33 beside it as the markings on top is not the same was hoping someone had a good quality photo or if they just happened to have the unit in hand, quickly take the cover off and take a photo to clearly show the marking on top to identify the diode   the unit is currently with an electronics repair shop so I can’t take another photo at the moment hopefully they are smart enough to know if it’s a zener diode or not
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
