  • Replies 59
Posted Images
Hi I was wondering if low 12 sec qtr mile passes are possible with the stock turbos that come on the rb25's?
What are the best times you guys have got using the stock turbos and what other mods?
i think i high 12's 1/4mile is achieveable if you can drive...
i was running 13.8 @ 106mph with not alot of power.
on that night a wrx with the same mph, was running 13.1 and i know of a soarer that has run 12.9 with 108mph...
so if you can get your car off the line and have good gear changes, a high 12 is do able :O
good luck :spank:
Its definately possible but has to be a perfect run. I ran many low 13's, 13.0,13.1 and then 12.98@107. That was with street tyres and even a SAFC and no PFC.
hi can you tell me all the mods you had when you did the 12 and the boost
  • 4 months later...
Would an R34 GTT with the following mods -
Split dump / front pipe
Metal high flow cat
3" cat back exhaust
Apexi filter
and running stock turbo at 11 to 12psi
Decent 225 street tyres
- and some good driving be able to get a 13.0 sec pass? Also would getting a GReddy E-Manage Ulimate and a good tune with the mods above push the car into the high 12's??
Ta ;)
There is no reason you cant get 13.0 or close to it.
It comes down to driver skill/car setup.
More runs you have, more expirience you'll get.
Although 225's are a little skinny, but its just practice
You didnt have 208rwkw ;) Not with 103mph at least anyhow.
With 220rwkw i was doing 109mph 12.9 (not stock turbo) with 2.2 60ft's.
Your 60ft isnt too bad for street tyres, maybe you missed a gear or something? If you didnt... then the car just doesnt have the power the dyno reads IMO.
13.5 is still a good effort though with 103mph for whatever power the car has
R33 RB25DET standard turbo running 10 PSI full 3 inch exhaust, pod filter, just jap front mount, running on 19/30/265 Nankangs atleast 50% worn (on the inside anyways)
13.648 @ 165.14 K/mh roughly 102MPH
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
