A GTR with the equiv usual mods (exhaust/ECU/boost etc) to the GTS-t should be low 12's if you know what your doing.
Hell, i know of one that dipped into the 11's on stock turbos and normal rubber... so mod for mod the GTR will always be a fair way infront of the GTS-t
Weight isnt as much of a disadvantage as 4WD is an advantage :laugh:
  • Replies 59
Posted Images
I don't know i always assumed that with a good full turbo back exhaust with dump pipe and hi flow cat, front mount, good cold air intake setup, power fc, fuel pump and a bit of boost and you would be in the 12s. Am i wrong for thinking this???
Well look @ Adrians results (2rismo)... does that not answer the question...? :D
Maybe Adrian can give a run-down of the mods that car had?
Daniel - IIRC the car adrian pilots was rev210's old car, and there is a link in the FI Guide to his project thread from a few years ago as it was very informative for its time.
http://www.skylinesaustralia.com/forums/in...?showtopic=9445
cheers
Well look @ Adrians results (2rismo)... does that not answer the question...? :wave:
cheers
It's my car - rev210 sold his R33 (in W.A.) and I've never even seen it! I bought his old Nitrous kit, maybe that's why you're confused.
I'll post specs later.
Adrian
The car had most of the usual stuff every other R33 GTST had. The Nitrous made 1 second difference.
Things like good tyres (not slicks) and LOTS of practice are mandatory.
Things like weight reduction and 300kW are not.
Adrian
Thats probably where im muddled then :wave:
Only been to the drags once got all the supporting mods but have a Safc no power fc. Managed a 13.6 @ 105 with a 2.3 sec 60 foot time, on a 30 degree day. The run I had was against a stript out BMW M3 with track racing tyres and few other mods. He ran a 12.9 @ 105 with a 1.8 sec 60 ft time. As you can see from the time slip there was nothing in it other than the launch I actually felt I was slowly reeling him in 3rd and 4th gear.
From this experience I think you would need some really good street tires with 60ft time bellow 2.0 to break into the 12's. So it is very possible
That was about the best I could do with 17/45/235 hankook silica tires.
cheers
One customer ran 13.0@113mph with exhaust,China cooler.Safc.
No changes made for the track and ordinary budget tyres.
113mph was stock turbo? Bloody excellent if so. Quickest I ever ran (without the bottle) was 111mph and this was in perfect conditions.
How fast do u guys think a r32 would go with 213rwkws? i was thinking about 110mph and a high 12 if i was lucky
The setup is is for circuit with 18x7.5s, 225/40 s-03 rubber and all the suspension parts from SK's GB
Edited by 2630GTS
I didnt see anyone with r32s posting hmm, ill re read
Edit: Ok i re-read and understand we are talking r33 with rb25 and stock turbo.
but the stock turbo on a rb25 can make almost as much as the 213 im making with bolt on turbo.
So i thought it wouldnt be a bad place to ask, considering most of they guys in the thread have actually taken there car to a dragstrip.
Never mind sorry to get off topic, its just ill never drag this setup and pretty sure it would have a high 12 in it, was just looking for a yay or nay :(
cheers tho
Edited by 2630GTS
13.1@105mph on 205/55r16 $50 tyres to pass rwc
with better tyres (non slick) i will for sure run 12. But traction is an issue with these street tyres.
Edited by LTHLRB
hey bit off topic too sorry.
ur running 7.5inch rims.. how wide tyres can u fit?
but u think u can fit 245 on 7.5rims? :no: im really hoping to.?
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
