I cant find a Blue Plate (nissan build plate) on my R32 GTST?? Only has a green compliance plate on firewall and aussie VIN etched on strut tower but not original jap VIN (which you need right?)
your vin might look like 6u90000er34002654 (posted earlier by someone) -- the original chassis number would be ER34-002654, which is what we put into FAST
Thanks Goofy,
Is there any chance u could tell me if this is a N1? I dont think it is but some1 claims otherwise
Eng no: RB26066194A
Vin: BNR32304039
Cheers
I'm not sure how to tell from the numbers (yet) - but apparently if you look on the side of the block and it says 24U its N1, if its 05U its standard
Edit: ok, KBNR32RXFS7 AA is the option codes it comes back with
It needs ZN at the end instead of AA to be a N1
Remix-: your pics not loading for me :)
Edited by Goofy[HSK]
Am I typing anything wrong for this to be run through FAST?
blockquote><p><a  href=http://img215.imageshack.us/img215/695/hnr32003113yf8.th.jpg' alt='hnr32003113yf8.th.jpg'>
If you put the option line in FAST first (KRNR32RGASLMAB) it then brings up another box asking for the vin.
It gets all the details about the car (gts-4, auto or manual etc.) from the option code - then just gets the production date from the vin. Colour codes didn't come up - i added them from your plate.
' date='23 Aug 2006, 10:16 PM' post='2433414']
My aussie VIN doesnt have anything to do with the original chassis number.
MY aussie VIN is 6F9IMPORTTH9K**** (I left the last 4 digits out).
Why would they have removed the original blue plate? Is that even legal?
I guess I have no way of finding out anything about my car, will make ordering parts from nissan hard too!
hmm... interesting - is there any other numbers on the firewall at all?
Hi guys. Never needed this thread until now but just want to check something. If someone could help out it would be much appreciated.
Can this software give part numbers for engine parts? Am I in the right place or is there some other software for this sort of thing?
I have been told that R34 GTR RB26DETT rods have the same part number as R34 GTT RB25DET. Could someone please confirm this for me or send me to the right place?
Thanks a lot.
Adam.
Thanks a lot.
Adam.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
