I cant find a Blue Plate (nissan build plate) on my R32 GTST?? Only has a green compliance plate on firewall and aussie VIN etched on strut tower but not original jap VIN (which you need right?)
your vin might look like 6u90000er34002654 (posted earlier by someone) -- the original chassis number would be ER34-002654, which is what we put into FAST
Thanks Goofy,
Is there any chance u could tell me if this is a N1? I dont think it is but some1 claims otherwise
Eng no: RB26066194A
Vin: BNR32304039
Cheers
I'm not sure how to tell from the numbers (yet) - but apparently if you look on the side of the block and it says 24U its N1, if its 05U its standard
Edit: ok, KBNR32RXFS7 AA is the option codes it comes back with
It needs ZN at the end instead of AA to be a N1
Remix-: your pics not loading for me :)
Edited by Goofy[HSK]
Am I typing anything wrong for this to be run through FAST?
blockquote><p><a  href=http://img215.imageshack.us/img215/695/hnr32003113yf8.th.jpg' alt='hnr32003113yf8.th.jpg'>
If you put the option line in FAST first (KRNR32RGASLMAB) it then brings up another box asking for the vin.
It gets all the details about the car (gts-4, auto or manual etc.) from the option code - then just gets the production date from the vin. Colour codes didn't come up - i added them from your plate.
' date='23 Aug 2006, 10:16 PM' post='2433414']
My aussie VIN doesnt have anything to do with the original chassis number.
MY aussie VIN is 6F9IMPORTTH9K**** (I left the last 4 digits out).
Why would they have removed the original blue plate? Is that even legal?
I guess I have no way of finding out anything about my car, will make ordering parts from nissan hard too!
hmm... interesting - is there any other numbers on the firewall at all?
Hi guys. Never needed this thread until now but just want to check something. If someone could help out it would be much appreciated.
Can this software give part numbers for engine parts? Am I in the right place or is there some other software for this sort of thing?
I have been told that R34 GTR RB26DETT rods have the same part number as R34 GTT RB25DET. Could someone please confirm this for me or send me to the right place?
Thanks a lot.
Adam.
Thanks a lot.
Adam.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
