Type M. Pretty sure all Turbo R33s are.
KN6 (Dark Grey Pearl) is my paint code too! Tasty as...
hmm thought type m's where special....are all turbo r33's really type m?
i know , its a beautiful colour , main reason I bought the car. Just coilovers wheels and exhaust and I love how mean they look
Edited by tripsteady
  • 1 month later...
Could someone please use fast to tell me the diff ratio of my 260rs stagea?
Vin wgnc34-106697
Can't use the build plate code as all 260rs start life as a rb25 with a auto and the don't change the plate
Thanks
Hey guys,
I am currently looking at buying a 1993 r32 gtr vspec. i just want to know if and how to make sure its a legit vspec?! Has brembo brakes yes, its navy blue in colour; is that a factory colour? Is there a way to tell using the vin or model numbers?
if someone could help would be much appreciated!
Vin: 6U9000BNR32301976
Model: KBNR32RBFS NA
Need to know asap if it actually is a Vspec!!
Hey guys,
Hi I'm learning with this program but happy to try to help. Here is your fast info.
TH1 means Dark Blue Pearl Paint
GTR.17 means v-spec from what i've gathered in previous posts.
Much appreciated! Can you please do this one aswell?
1996 R33 GTR (Vspec?)
Vin: 6U900BCNR33022988
Model : GGJPRQFR33ZDA-A-AA
    • Nah, nothing formal, just open track days. Mostly small and tight circuits but I would like to get back out to Eastern Creek at some stage.
    • What type of track driving will you be doing?  Do you have a set of class rules you need to abide by that will limit your rim / tyre width?
    • I've been reading a lot lately about unsprung weight and how beneficial it can be to reduce it for driving on the track, given my semi's only have another day or two in them I am throwing around the idea of some lighter wheels and a square set up. I have 265/35/19's and 245/40(?)/19 Federal 595's at the moment. The wheels and tyres are super heavy. I looked up my wheel weight online and got 14.5kg naked. Not sure if this was 8.5 (front) or 9 (rear) but that's a lot. I have also been reading about the benefits of a square setup. Much better rotation and potentially less understeer.  When I throw these together I'm thinking about a 17x9 or 18x9 square (preferably under 10kgs per wheel) with 245 or 255's. I can get some cheap 17x8.5 BMW M Sport wheels, they weight 10.5 kg's each but at 8.5 wide could probably only get 245's on them? I know they come with 255's from factory but semi's are a bit chunkier. Otherwise it will be aftermarket wheels in a 9" width. Most of the other BMW wheels are heavy unless you pay a squillion dollars for some M wheels.  Although, the E46 M3 Style 67's could be good but I'd have to buy 2 sets to square them up.  My car has a tickle over 400hp and about to put an LSD in also, is 245 a little thin for a square setup? It kinda feels that way to me. Also, is there any tangible benefit to having 18's over 17's? Is the footprint demonstrably bigger? From those of you who went to light(er) wheels after heavy buggers, did you notice it much?
    • Start with the R32 GTR wiring diagram. The ECU is essentially the same, so the pinouts are good. The details around ECCS relays, etc might differ a little bit, but the reality is that you need to get ignition power to kick the ECU so it powers up the ECCS relay which brings the rest of the ECU up. This also gives power to the other circuits that are needed to make the engine run, like the ignition coils, etc. All of this is visible on the R32 diagram and should give you a strong guide, even if it's not quite the same as the R33. As to specifics - I'm pretty sure no-one can help you from afar, as there is no way to know what mistake or omission has been made in connecting stuff up. It always turns out to be "LOL, I shorted something and an entire wire vanished out of the loom", or "We never connected X or Y main connector", or "shit, you mean I need to have that fuse installed?".
    • hello wanted some insight on what my problem could be so i swapped a RB26DETT into my r33 gtst used a R33 GTR engine harness and im using a haltech platinum pro. The car cranks but no start the ecu isn’t getting any power now im trying to find out why i cant seem to find any schematics  or diagram for the engine harness for the r33 gtr anything helps thank you.
