Thanks for that....
There was a car for sale which the owner mentioned it was a Vspec II, but it doesn't have the number 8 after RBFS....
so I'm assuming its just a Vpsec
I see,
Yeah that's right, if it does not have the number "8" or if there is a digit absent, meaning it is a V-Spec (non V-Spec II).
And since the build date is Feb 1993, it indicates it is a V-Spec.
V-Spec II are built from Feb 1994.
  • Like 1
Will have to look at the Engine Block.
Usually if the Block is embossed with "05U" = Standard.
Embossed with "24U" = N1.
Also check the turbo part numbers, from memory, R32 GTR N1 Engines came with Nismo Turbos, like the R32 GTR Nismo Editions.
R32 GTR Nismo Turbo Part Number (14411-06U00).
Might have to get someone on here to decode that engine number.
Engine wise, Base Model R32 GTR vs R32 GTR V-Spec + V-Spec II, there is no difference.
V-Spec's came with Brembos and 17" BBS Wheels with 225 / 45 /17 Tires.
V-Spec II, same as above but with Tires sizing of 245 / 45 / 17.
  • 3 weeks later...
  • 8 months later...
Afternoon guys, was wanting to get the following vin checked please re; info on the specification of the car
Many thanks,
BNR34404208
One of the Spec Codes indicate it's a M-Spec.
Is it a M-Spec or M-Spec Nur?
Car is a base M-Spec, i'm currently having it inspected at racepace VIC, as i'm in sydney
thanks a heap, I can always rely on you guys to come through with information, much appreciated
Sorry my fast isn't picking that one up... hopefully someone else can help you with it.
Thanks for trying mate, appreciate you taking the time to check
The car in question is here - http://www.carsales.com.au/private/details/_/SSE-AD-3480145
not as tidy as the photos lead on from Racepace's feedback, but i hope it's got my name on it
  • Like 1
I see.
Not bad for the price.
Low Km's, done up nicely for looks and assuming "Lightly Modified" would involve an exhaust system at least.
Higher price then the usually GTR's only cause it's a M-Spec.
Racepace will be the best to give you the answer and I am a customer of theirs too so I can assure.
  • 4 weeks later...
  • 2 months later...
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
