i tried doing this with mine and it didnt work :rofl: so i sold the rsm and got a navara drive
Damn, that sucks. So I hafta get a new speedo cable with the plastic bit in one piece aswell. I've already ordered a AVC-R, haha, at least its a good boost controller, not just a speedo.
  • Replies 188
Posted Images
dunno bout that, i sold my AVCR also cause it didnt control boost for shit....
but yeah, i need a new plastic thingy for the cable also as mine has now broken... and you cant buy themk seperate from nissan, need the whole cable
Serious, I always thought AVCR was up there with eboost.
I've heard of people getting the plastic bit replaced with something stronger, was thinking of ways to make it myself but the hard part is getting it to fit back on the shaft (cable) because its got that bell shape around it so you cant get to it to make a slot or anything.
Simply have the yokes swapped and tail shaft balanced.
Take as little off it as possible. Remove ~12-15mm removing the old yoke and weld.
Mine and Salads was done this way fits fine. :nyaanyaa:
Balance and yoke swap is around $160. Get a couple done at the same time and its cheaper. :w00t:
hey everyone just a bit back to the origin of the post, i have got the navara sender and r33 cog, put them in the gearbox but it was a tight fit, didnt realise that the sender had to be rotated 180 degrees with a slit in the side and now its stuck in there real good, snapped off some of the thread trying to get it out. any ideas on how to remove it?
Spray WD in there and hope it helps the rubber seal to slide a little, then lever it out via the existing slot.
When its in correctly (180) its a fairly tight fit as the seal grabs if you don't use vaso or gearbox oil on it.
Mine and Salads was done this way fits fine. :)
Balance and yoke swap is around $160. Get a couple done at the same time and its cheaper. :D
Nah, I'm getting a one piece made up with bigger replaceable uni's. Don't wanna risk using the stock tail shaft with 350rwkw's. Did anyone measure the distance or did everyone just cut, weld and fit?
Cheers
I've attached a pic of the rb25det gearbox sitting in the car and the rb20 tailshaft up against the dust shield.
As you can see the 20t tailshaft sits slightly inside the box; by the time you remove/cleanup/chop off the old weld and reweld the new yoke on the dust shield lines up perfectly with the rb25 yoke.
Don't take off any more than you have to otherwise the yokes dust shield section will hang outside of the gearbox dust shield.
Premo, i get my rb25 yoke on Thursday so i'll be getting my tailshaft mod done soon at the same place as joel and showza (adelaide tailshaft services) might be able to get them done at the same time, even if your doing yours a little different to mine.
Thanks for the offer but I'm getting a one piece made up, a bit bigger and stronger. While your getting the tail shaft made up could you measure the distance between the diff flange and the furthest point of the gearbox just so I can make sure the tail shaft I'm getting copied is the right length??
The one I'm getting copied is from an R32 with SR20 and Z32 gearbox so it should be the right length but I wanna double check before I go get it made up, my gearbox hasn't been delivered yet so I cant get the measurement myself. Or If anyone knows the difference in length of an RB20 box and R33 box I could work it out.
Thanks
Edited by =premo=
Pretty sure I mentioned this in another thread.. when we had my engine out to put the new crank/bearings in, I put my stock tailfshaft up next to that out of a 32gtst with an rb26 and 25 gearbox, they were practically the same length minus the saw cut (~1.5-2mm).
Nice one, thank you.
Thanks Cube's for the pic, makes sense now.
Simon, check your PM's
Edited by =premo=
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
