i tried doing this with mine and it didnt work :rofl: so i sold the rsm and got a navara drive
Damn, that sucks. So I hafta get a new speedo cable with the plastic bit in one piece aswell. I've already ordered a AVC-R, haha, at least its a good boost controller, not just a speedo.
  • Replies 188
Posted Images
dunno bout that, i sold my AVCR also cause it didnt control boost for shit....
but yeah, i need a new plastic thingy for the cable also as mine has now broken... and you cant buy themk seperate from nissan, need the whole cable
Serious, I always thought AVCR was up there with eboost.
I've heard of people getting the plastic bit replaced with something stronger, was thinking of ways to make it myself but the hard part is getting it to fit back on the shaft (cable) because its got that bell shape around it so you cant get to it to make a slot or anything.
Simply have the yokes swapped and tail shaft balanced.
Take as little off it as possible. Remove ~12-15mm removing the old yoke and weld.
Mine and Salads was done this way fits fine. :nyaanyaa:
Balance and yoke swap is around $160. Get a couple done at the same time and its cheaper. :w00t:
hey everyone just a bit back to the origin of the post, i have got the navara sender and r33 cog, put them in the gearbox but it was a tight fit, didnt realise that the sender had to be rotated 180 degrees with a slit in the side and now its stuck in there real good, snapped off some of the thread trying to get it out. any ideas on how to remove it?
Spray WD in there and hope it helps the rubber seal to slide a little, then lever it out via the existing slot.
When its in correctly (180) its a fairly tight fit as the seal grabs if you don't use vaso or gearbox oil on it.
Mine and Salads was done this way fits fine. :)
Balance and yoke swap is around $160. Get a couple done at the same time and its cheaper. :D
Nah, I'm getting a one piece made up with bigger replaceable uni's. Don't wanna risk using the stock tail shaft with 350rwkw's. Did anyone measure the distance or did everyone just cut, weld and fit?
Cheers
I've attached a pic of the rb25det gearbox sitting in the car and the rb20 tailshaft up against the dust shield.
As you can see the 20t tailshaft sits slightly inside the box; by the time you remove/cleanup/chop off the old weld and reweld the new yoke on the dust shield lines up perfectly with the rb25 yoke.
Don't take off any more than you have to otherwise the yokes dust shield section will hang outside of the gearbox dust shield.
Premo, i get my rb25 yoke on Thursday so i'll be getting my tailshaft mod done soon at the same place as joel and showza (adelaide tailshaft services) might be able to get them done at the same time, even if your doing yours a little different to mine.
Thanks for the offer but I'm getting a one piece made up, a bit bigger and stronger. While your getting the tail shaft made up could you measure the distance between the diff flange and the furthest point of the gearbox just so I can make sure the tail shaft I'm getting copied is the right length??
The one I'm getting copied is from an R32 with SR20 and Z32 gearbox so it should be the right length but I wanna double check before I go get it made up, my gearbox hasn't been delivered yet so I cant get the measurement myself. Or If anyone knows the difference in length of an RB20 box and R33 box I could work it out.
Thanks
Edited by =premo=
Pretty sure I mentioned this in another thread.. when we had my engine out to put the new crank/bearings in, I put my stock tailfshaft up next to that out of a 32gtst with an rb26 and 25 gearbox, they were practically the same length minus the saw cut (~1.5-2mm).
Nice one, thank you.
Thanks Cube's for the pic, makes sense now.
Simon, check your PM's
Edited by =premo=
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
