yep fred from pro trans did the box for me i think its gonna be a big difference especially with the trans brake neva used one .. has anyone here used a trans brake whats it like...
Edited by campbell
  • Replies 74
the hardest thing about using a transbrake is getting used to not hitting the brakes when you hold it flat but its easy
just get into stage hold the button until you hit the right boost or rpm
i leave the line at 5000rpm with 10 psi boost
any questions pm me
put a boost gauge and 5" rev tacho close to ur steering wheel so u can c it straght and clear. I have 3 speed in mine. 1st u switch your transbrake solenoid on, hold the button then rev it to 5,000 or something, boost will hit 15-18psi. leave the button then you'll get "quickest launch ever". dont hold that button for too long, 5-6 sec max, other way u will cook ur trans. get a big trans cooler !, and dont press it again when you launch, your trans will go back to reverse and brake ur auto internals. autos are jsut like a tune and engine, you need correct stall size to suit ur turbo, and cam and then retune it to match everything... very hard man. You bought the best auto for drags, good luck
Love the sound of the T51R, always have and probably always will :P
As for being the quickest, I'm not sure about times but there was an R33 running a factory-capacity RB25, making 795rwhp getting around Brisbane, was built by Hardcore before they ceased operations and had NIS33 on the plates. Also, 40RCD (now TRY09) might be worth checking too, I don't know if it still runs an RB25 bottom end but last time I saw it, it was running some very decent times. It was definitely 2.5 litre when it was running mid 10's, and I'm fairly sure it was still 2.5 when it broke into the 9's too, but I don't know about now :)
Best of luck ;)
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
