hi,
im just very confused right now about tunning a GTR........the tuner i prefer does not have a 4wd dyno, and he is going to take the front drive shaft out and tune my car on RWD mode.
would this actually affect anything on my car??? or does it do anything to Attessa system at all??
any info would be greatly appreciated.
cheers
https://www.sau.com.au/forums/topic/134767-tuning-a-gtr/
How come ur using someone to tune ur car when they dont own a 4wd dyno? Maybe take it to somewhere that has a 4wd dyno and then u dont have to buggerise around with removing the driveshaft.
P.S frank, was over at dan's picking up some parts last nite, and gotta say lovely car u've get there mate :rofl:
https://www.sau.com.au/forums/topic/134767-tuning-a-gtr/#findComment-2505062
nothing to worry about. many tuners only have RWD dyno. 4WD would be prefferable, but if all he has is RWD then disconecting the front prop shaft and running the car in RWD is no problem at all.
https://www.sau.com.au/forums/topic/134767-tuning-a-gtr/#findComment-2505090
Frank i got my GTR tuned 2wd mode.... Richo at Allstar done mine, and he's only up the road from where you are... drop in and have a chat with him.. couldn't hurt...
Noy, was gonna pm you for some advice...thanx man
i know Richo is a really good tuner( got things done by him before), but he hates Power FCs as anything........
i am gonna get Gavin Wood and Matty Spry to tune mine next week....
once i get Motec or HalTec with other mods, i will bring it down to Richo, and then he will be gald to do it.
Edited by frankxinyu
https://www.sau.com.au/forums/topic/134767-tuning-a-gtr/#findComment-2506364
why would it matter if it was on a 2wd dyno or on a 4wd dyno, they are not awd they only use the front wheel drive when the rear wheels brake traction so really they are a RWD car untill the rear whells spin
not true at all. do you own or have you driven a GTR? AWD is computer controlled and is engaged under lots of different circumstances. a lot of the time there is some amount of FWD being engaged.
https://www.sau.com.au/forums/topic/134767-tuning-a-gtr/#findComment-2507202
further to this the 33 & 34 gtr's always have some amount of front wheel drive, hence why u have to pop the front drive shaft to put in constant rwd
https://www.sau.com.au/forums/topic/134767-tuning-a-gtr/#findComment-2507533
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
