Batmbl Gb #3: Twin/split Dump & Front Pipes In One + 3" Hi-flow Catco Cats (optional)
  • Replies 113
Holy pain in the ass batman
I cant even get my old one off so I cant say if it fits or not yet
can only get five of the 6 nuts off
is there a trick to getting a spanner to the nut in the middle closest to the inner guard ??
Mines got an aftermarket dump pipe on at the moment and its proving to be very difficult to remove
Just be careful, we snaped off the top one in the turbo exhaust manifold, now we have the wonderful task of removing it :) Have you tried spraying WD40 or similar and letting it sit for an hour or so, this may help a little. ;)
The quality of these split dump pipes and metal high flow catco cats are excellent, I can highly recommend them if any one is considering a purchase!!! :O
SS8_Gohan - Maybe I am just being a bit fussy, it does fit but just sits too close to the body at the cat end for my liking, but this problem is easily fixed and I am not complaining, but that could also be because I have an R34 Series 2 sedan, I dont know if they would be different to coupe's or Series 1's??
Ay every one i just perchased a catco 3" metal cat and was just wondering has anybody had trouble with the 5" center.. like dose it scrape on everything etc.. cauz currently my dump pipe is the one that scrapes on speedhumps..
hmm... i've finally paid for my split pipe, not too keen on this "not fitting quite right" business :laugh:
If you are referring to my experience, it fitted perfect, i just had to get a slightly shorter bolt for one of the holes (or cut a little off the end of the old one).
I also found that with the new dump and metal cat, my ground clearance was better than with my stock cat.
I got it fitting by a workshop though, cost $80 or so. Well worth it.
Finally got it on
wasnt so bad after all
had to go buy a stubby spanner set to get to the bloody nuts
but it fitted straight up
and after driving it i wouyld say it does spool up alot faster now and power feels more linear (smoother)
referring to other R34 owners ;)
EDIT: oh... got the pipe... now for the catback (already have a BATMBL 3" cat) HKS Super Dragger anyone? ;)
Fugi,
the cats being made up today and should be delivered to me on Monday or tuesdays at most. i will get it sent out then and you should recieve it by end of next week as it will be sent from syd.
cheers
hi guys
i have PMd all those registering interest in another GB. i might be able to arrange a small GB if most interested parties want to go ahead.
cheers
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
