BOV - waste of money.
A RB25 has an AFM so expect the car to stall, blow black smoke, and carry on.
Sure, you'll think you sound cool with a big "whooooosh" but you won't sound cool when it stalls when you pull up next to whoever to are trying to impress.
Edited by The Mafia
they do have issues, they just dont know it.
if they have the option to plumb back their atmo's, tell them to try it, and adjust it to a soft spring setting so it opens under least pressure. their idle will improve, and possibly response. mine was running great with atmo, even better now with plumback.
how does that work? their cars idle fine, don't really blow any crap, and response is fine. in fact i've had more of symptoms commonly blamed on atmo bovs with my stock plumback.
well i'm not using a stock bov, and have 0 experience with them.
i'm using a GFB hybrid full plumback.
on atmo my car would idle well, but at high revs, then off gas and hit brakes hard, the idle would drop very low, before it recovered and even stalled a couple of times. as soon as i plumbed back, issue gone, and idle was even more steady. that's my experience anyway.
I had a GFB hybrid BOV when I first got my car... prior BOV it went fine, with atmo BOV settings the car started playing up, stalling etc. I then fitted a loose POD and the car totally f**ked up. The AFM solder went haywire... regardless I put the stock BOV back on, got another AFM and put my stock air box on.. car runs perfect now.
ATMO BOVs = hassles. Although I do admit I loved the sound.
Edited by Sir-D
I have recently upgraded on my 33 from the stock bov to the GFB 1004 Basic atmo bov. I get a backfire sometimes, but it shoots flames so meh....never stalled, never dropped revs, nothing. I had a fabricator make up a custom flange and gasket for my bov so it fits perfectly...none of these shitty turbosmart flanges u get from autobarn...
While i'm not exactly a fan of atmo bovs...i must say that i haven't really had any stalling issues with any of the atmo bovs i've tried on my past turbo cars...i've had HKS, Turbosmart, Apexi and ARC bovs and they were fine...backfires did happen more frequntly but i certainly wouldn't consider that a problem...they just have to be adjusted properly...
My BOV is atmo and I experience the issues described above, on gas to no gas revs will drop to like 400, engine will splutter a bit then idle returns to normal. Has stalled a couple of times because of this.
It had the atmo when I got it. Cant say as its on my list of things to fix at this point but.
skylines are the first turbo car that i have heard of having stalling issues with atmo bov's. i had one on my 180sx. had the occasional pop on gear changes, but thats it. it wasn't until i got on here that i heard of it. there's a few dozen turbo cars where i live, and all but mine have atmo bovs and none have had any issues that i'm aware of. and all but 1 or 2 run factory ecu's.
I only ask because my GTR came over from japan with the recirculatory system removed, this means that the stock bov's are running atmoshperic.
I figured that being the case I should propbly use some valves that are designed to be atmospheric, to reduce the above mentioned issues.
you'll find after modding the car further from standard the stalling issue becomes more apparent.
I laught at idiots with super loud whooshy twirly stuttering whizbanging cock extending spinny BOVs, because they make all this noise, try and be tough, and then try and drag me......
And get promptly smoked, and shocked to hear the roar of a turbo, that sounds like a 747 landing when coming onto boost...
come down to the sunny coast and try that trick. i'm sure there of plenty guys down here that will do the same to you.
Wow you're so cool...but seriously...isn't that a pot calling a kettle black...they get a kick out of the sound of their bov and u get a kick out of the sound of your turbo...
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
