Thanks guys - how old do I feel ! 39 yesterday. Ha ha.
Sat on my arse all day infront of the TV and computer - Having a busted leg is no fun !
Tosh - Once the leg is better, I plan od getting out to see you guys some more - Now that I have a half decent car again !
Project Cosmo is coming along well - with a few suprises coming up :(:):P
copulater
B-Man
I farking can't help myself......
Told myself I was going to keep the Cosmo pretty much stock - and modify the shit out of the TX3 - Now I am doing both - and spending heaps more $$ on the Cosmo.....
Oh well, guess it is in my blood.
I have NFI how the Cosmo will go with the T04Z - the only comparison I have are some 20Bs with either the T04S or GT3542 - And in my opinion the HKS T4O4Z is better for spool and top end than both of these.
Should be good though - 20B will bring on the boost pretty quick and the turbo is rated to 700 or 800PS depeding on where you get your specs from.
Now for a wastegate - oh, whoops - I just found one...........
At least the Cosmo will stop well - it will never be a track car - but I might take it out on the track after the............. wait for it...............
Manual Conversion........ - OMFG - Did I just say that.....
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
