hi i have a stock r33 gts-t running stock boost
only mods is 3inch turbo back zorst and pod filter with power fc
any increase in performance if i install a better fuel pump? maybe a 040 or 044 bosch?
mite change the actuator to make it go constant 10psi..
https://www.sau.com.au/forums/topic/137308-upgrade-fuel-pump/
Just get some gasket paper, trace the stock BOV flange onto it and cut out the same shape. Make two holes for the bolts and put it between the stock BOV and where it sits. Viola.
another quick question.. i don't wish to use my stock bov is it the same to simply tie up the hose as it is to completely remove and seal the metal?
Hey does the PowerFC give you much gains with stock boost, exhaust and filter?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
