Guys,
I after a GTR Style front bar for a Series 2 R33. I've tried to get one through Carmate but there is a
month wait. My car is at the panel beaters and I'm kinda after one asap. I've called up quite a few places
but can't get a hold of one.
Does anyone know where I could get my hands on one pretty quickly..
Again sorry about the boring topic!
https://www.sau.com.au/forums/topic/137422-r33-front-bars/
the stock series 2 bar is ace, no other aftermarket front bar looks as good imho. and a gtr bar on it will just look odd, your missing flared guards, different bonnett, twin turbos, 4wd drivetrain etc :)
https://www.sau.com.au/forums/topic/137422-r33-front-bars/#findComment-2568118
[silhouette]' date='10 Oct 2006, 01:18 PM' post='2569734']
Does anyone know if the Series 1 bars fit onto the series 2?
Yes it does...
My Banana bar will fit onto a S1 and a S2
Bar doesnt look 100% in this pic as the reo needed to be modified for the bar to fit... This is standard with most aftermarket front bars for a S1 or S2 espec if you have an opening for an Intercooler...
https://www.sau.com.au/forums/topic/137422-r33-front-bars/#findComment-2569861
IMO the reason s2's look sweet is cos of there standard front bar, I agree with paul and putting a gtr bar on an s2 also looks odd cos the headlights are sharper on the s2 and it just doesn't really work. The s1 on the other hand is a different story...
https://www.sau.com.au/forums/topic/137422-r33-front-bars/#findComment-2601834
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
