I am in the market for a new turbo for my RB25 ERC33, I had reason to ring GCG and while talking to their Sales Manager, Mark Landell, he mentioned that they can provide me with the internal wastegate Garrett GT3071R with a custom T3 turbine set up [they come out with a T28 std]. He reckoned this set up is a easy install bolt on equivalent of the HKS 2835proS.
Now I’m not knocking GCG, they have an enviable reputation and I've only got good things to say about they myself, and Mark is very likely a good man and knows his stuff. But he was a bit reserved when it came to talking up this turbo’s performance and likely power output. He reckoned 250rwkw was a good starting point and that maybe a bit more. This sort of threw me because the HKS 2835proS has figures quoted more like 300rwkw. And I’m already making 240rwkw with the turbo I’ve got, so I really want to upgrade, not move sideways.
I just wanted to see what everyone thought? I know discopotato has written some stuff on the 3071 external wastegate and is keen on an internal version, but is what GCG offering just such an animal, or is it something else/less.
The turbo GCG are selling has a 0.50 compressor cover, a 56 compressor wheel trim, and an 84 exhaust wheel trim and is rated at 450hp, but because it is new on the market, they really had no installed real time power output figure.
https://www.sau.com.au/forums/topic/137613-gt3071r-internal-wastegate/
a 450hp wont throw you to 300rwkw.
Thats what I thought, but its like they are saying no it won't/yes it will. On one hand they put out a 450hp figure, and on the other they say it is the direct equivalent of the 2835proS? Ambivalent messages methinks!!!
putting the larger comp wheen into the stock turbo is a bad idea
GCG did this in thier "stage 2" hi-flow and ended up stopping it because of the surge issues etc.
You'll have to step up a frame to the GT30 series with the GT40 wheels if you want more than the GCG provides.
Talk to Slide off this site! I just bought a GT30r off him
here are the specs
Specs:
Turbine:
-84 trim 60mm GT30,
Compressor:
-76.2mm 56T compressor
Compressor housing:
4'' inlet
500hp rated
Dual Ball bearing core
Internally Gated
Exhaust housings:
T3 inlet GT30 outlet 0.82
& also GCG offer the same thing except they rate this turbo @ 600hp! Anyone know why?
trident, if you are unsure whether it will outperform a HKS 2835 pro s (remembering that both the GT3071 & HKS 2835 pro s use a 71mm compressor) and then the only way to be sure would be to go the 76mm compressor.
if GCG are talking about the GT3071WG disco is going to try to talk you out of it as it has the cropped turbine, if it is new then it may be one of the new internally gated garrett housings.
ask about GT3076 that should give you a little more headroom or splash out on a HKS3037 (the HKS version of the 3076)
check atpturbo.com as they can supply a genuine GT30 internally gated turbine housing that you can mate to whatever combo takes your fancy.
Edited by wolverine
Yes, I've looked at the Gt3076, I reckon it would be a better bet. If I got it with a T3 and a good exhaust turbine combo it would be close as.
If you read the first post, I state that the GT3071R is an internal. I really don't want to go to external, I believe that I can get everything I want out of a good internal wastegate.
And just to set the record straight don't want 300rwkw, but I want my turbo to be capable of it if I ever do want to. I am really only looking at around 270-280, the motor is untouched except for cams.
trident i read your first post and understand you want a internal gate. if you go thru the garrett catalogue they offered a GT3071WG with a cropped 56mm turbine, it is an internally gated turbo.
however it doesn't use a genuine GT30 turbine housing.
hopefully the one GCG are quoting is one of the new 'genuine' GT30 housings with 60mm turbine (not 56mm) and internal gate.
if it isn't you could order one from ATP and buy the rest locally.
No, they are offering a GT3071R with a custom turbine ie they replace the T28 with a T3, it is internally wastegated. It is a very new offering and not listed on their catalogue, I asked why I couldn't see it on their site as well and that was the reply. But overall I think it will be too small for me anyway, so have gone off the idea. going to have a yarn to Slide first and see what he can do..........[its only money, haven't touched 2009's wages yet..lol]
Yes I'd want to know the turbine dimensions not just its trim .
Just on the "cropped" GT30 turbine in the 2835 and 3071R-WG , its the GT28 exhaust housings that turn it all to shite not the turbine . The 2835 Pro S turbos use that turbine as well and they are not too bad but remember they use a GT30 based exhaust housing .
Before Garrett released their new GT30 and GT35 IW housings I was told GCG had been using some other T3 flanged IW housing but I not sure what type .
If it were me I'd be insisting on the real GT3071R with the full sized GT30 60mm 84 trim turbine . Garret now makes a propper GT30 IW T3 flanged exhaust housing and I would use nothing less on any GT30 turbine based turbo . Have a look at ATP's site at the REAL GT3071R , they don't mention "real" but its the one without the "WG" tacked on the end of it . The site shows a selection of exhaust housings so they can obviously sell it with the good IW GT30 housing .
Cheers A .
So how does that gt30r compare to a gt3071r?
Specs:
Turbine:
-84 trim 60mm GT30,
Compressor:
Compressor housing:
4'' inlet
Exhaust housings:
500hp rated
Internally Gated
Edited by al_r33
Going off Garretts current numbering system a GT3071R is a GT30 turbine with a 71mm Major OD compressor . The GT3076R is same deal with a 76mm compressor instead . So 30 + 71m or 30 + 76mm - 3071 or 3076 .
Personal opinion but the GT30 turbine is struggling with the 56 trim 76mm wheel so response is compromised slightly . The 52 trim 76mm wheel works well but is only marketed by HKS I believe , called GT3037 52T .
The GT3071R is supposed to be a production version of Garretts competition only TR30R using their off (their) shelf wheels . In theory its good for 440 Hp but at high boost pressures .
By response I mean boost threshold as well as the transient response of the turbos rotating group .
Out of time cheers A .
is this the turbo that your refering too?? or similar. i have just purchased one with the .63 nissan housing on it but am yet to have it bolted up to see how it goes. it should be alright however for the moment im a lil sceptical about the 500hp rating on the turbo and obviously not gonna make that power on the .63 housing. having said that the reason i went for this turbo was that it was easy enough later off down the track to bolt on a .82 ex gate gt30 housing (funds wernt permitting when i purchased this turbo to eg gate setup.) and try for bigger power.
http://www.horsepowerinabox.com/HPIAB2/prod18.htm
this is the link for the same turbo on atp turbo
http://www.atpturbo.com/Merchant2/merchant...tegory_Code=GRT
this is the turbo i have, its identical same antisurge comp cover and all, just the .63 nissan housing.
Edited by drag-on silvia
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
