Alright, my engine should be getting dropped back into the car Monday/Tuesday but am concerned about my radiator, oil cooler and oil pump. I am going to have around 400rwhp when dynoed, so are the any recomendations on aftermarket gear or will the standard items be able to handle it?
In case you don't already know, I have a R33 GTST S1 with the following mods:
G-Max Wheels rear: 18x9.5 with 265’s front: 18x8.5
Tein hight and rebound adjustable suspension
Full 3inch custom exhaust with Magic Cat and twin Mufflers
Ball bearing T70 turbo on X-Force highmount manifold
Turbosmart 48mm Pro-Gate wastegate
100mm think Front Mount Inter Cooler
Blitz blow off valve
Sard fuel pressure Regulator
Sard 550cc injectors
Walbro 500 horsepower fuel pump
Motec Enginge Management System (M600)
Exceedy 5 puck clutch
Pod air filter
Oil catch can
Additional thermo fan (2 in total)
Bonnet vents
Isotta Steering wheel
DBA 4000series sloted disks alround with braided lines
Braided fuel-line, blow-by, breather and radiator overflow hoses
New chrome radiator overflow tank
Gates Racing radiator hoses
Viper 790VX Pager car alarm
20thou Arias Pistions
Adjustable cam gears
Full gasket and bearing kit
Cometic head gasket
GTR rods
ARP head studs
Is this enough to keep the car from overheating?
Edit - f**ked up the hp figure.
Edited by phee
https://www.sau.com.au/forums/topic/137670-getting-high-hp-and-staying-there/
Bigger injectors, 740's is where your gonna be at now :D
Walbro - wont be upto the task either. Time for a surgetank, walbro lifter and bosch feeding the rail.
What oil pump did ya stick onto it?
And i would be using a bigger ally radiator... around $660 for them give or take
Got ducting on the intercooler?
What I mean is that air is directed into the 'core' of the intercooler and then ducted through to the core of the radiator.
The idea is to 'seal off' the gaps around the edges of the intercooler so that the air hitting it has no where to go but through the core.Quite a bit of air will happily 'wash' around the intercooler over the end tanks etc. if there are lovely gaps there as they create a relative low pressure zone. It's best if you can direct the air into the core in a sort of a slightly 'angled in' way rather than just sealing it around the end tanks.
The goal is to channel all the air into the core of the intercooler and through the radiator and then perhaps out a back facing bonnet scoop angled towards the radiator. Alternatively grabbing some washers and longer bolts for the bonet hinge you raise the rear of the bonnet so that you have a small gap at the back edge when its closed.
Make sure you do the same thing for mounting an oil cooler and always remember to have a radiator shroud for any fans you have on it, electric or otherwise.
Edited by rev210
oh forgot..
turbo beanie and thermal tape the dump pipe. If you have the coin then ceramic coat the turbo exhaust housing, dump pipe and x-force manifold and tape it as well. That will get the under bonnet temps down big time.
The pod filter is in a nice cold air induction box too I hope, with a good air feed.
upgrading the cams in my opinion is a priority. You will increase the power band a great deal, decrease the rpm needed to get boost , decrease intake charge temps due to lower restriction at the valves and reduce the needed boost pressure to make the same power if you decide to limit/cap it at 400 or whatever.
You have some very expensive supporting mods. You don't build motors around this sort of power target without changing them (cams), thats what I call a half assed approach.
you spent all your money on the motec lol.
that above list should be fine. the fuel pump will be feeling the presure.
just put anotherone in there to help it. (they can fit) and are cheap enough.
the turbo.. id keep an eye on it. to help it stay alive just do the nessesary cooldown n shit.
keep the boost to 1.1bar max and it will love ya for it :mad:
i dont see an oil cooler there? just jap have some coom serk copies for shit money. hows a 36row for 150 bucks grab ya :)
PWR radiator, regualar coolant changes header tank
Tape up any hot pipes, ie exhaust, intercooler pipes.
ANd fuel system upgrades....
These are all mentioned but that would be my priority based on your location.
I said PWR to cause you get what you pay for, PWR cores are lifetime warranty and are substantially heavier and higher grade alloy than competitors offerings this will help with heat soak!!!
Cheers
I have just finished reading the N1 oil pump thread in General Discussions, and now I bit concerned about getting an N1 pump, however I will need to get something.
Another fuel pump? As in aditional, or get rid of the one I have and buy something with a higher cc? Radiator will need to be upgraded regardless.
Oil cooler, can someone explain this a bit further?
And yeah I spent all the money on the Motec, and it came with a free R33 Skyline :whistling:
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
