My crank angle sensor still have a sticker on 1 screw. Does it mean that my timing belt hasn't been changed??
Seller told me that timing belt was changed. By looking at the sticker here, it looks like the stock sticker.
Can someone confirm the sticker.
i have 100000km on my R32 gtst.
So i guess it is time to change.
If the timing belt has been changed or a 100,000km service has been done, there should be a sticker with the date it was changed and the kms when it was changed. This should be located at the top of the cam cover.
See here for more info: http://www.skylinesaustralia.com/forums/in...&hl=sticker
The sticker in this pic means that it is "recommended" that you change it at 100,000kms
i dont recall ever seeing that sticker on a CAS. it's most likey just there to stop people adjusting the timing once it was set. you could be right though. was there any receipts or service stickers to indicate that the timing belt HAD been changed?
No, i dont have any service record. Seller said it was changed but i dont believe that.
There is a sticker on the radiator, but i believe it is to show that the radiator liquid flush got change.
No sticker on the timing belt cover.
I do believe that the sticker on the screw of the CAS is stock.
I remember seeing a low km skyline and it got that sticker on the screw that looks fresh from the factory.
Is it easy to remove the timing belt cover? I would like to have a look at it, but im afraid to mess up with the timing from the CAS.
My CAS has the same sticker/tape. It had 68,000km on a wound back odo when I picked it up. I have no idea if my timing belt has been changed.
doodz not everyone has a 100,000km stamp. I'd be surprised if anyone other than Nissan stamped the head during that service.
the sticker is broken so the sensor has been moved or taken out
the sticker was broken on the side, probably due to its age.
if you look carefully in the picture, you can still see a part of the sticker covering the screw.
I doubt that someone will put back the sticker after opening the CAS.
yeah, no-one would use a screw driver to undo bolts. well no one smart anyway :teehee:
if it's broken on the side then it you be a safe bet to say it's been removed. all that means is that someone has removed or loosend the CAS. still doesn't tell you if the timing belt was changed or not.
you are right! :) No one will remove it with a screwdriver. :(
Now i still want to check if the timing belt was change.
Can someone tell me if it is easy to remove the CAS?
Just unbolt and mark down where the bolt sit, and remove?
Then put back at the same position??
Yes but you will have to check timming with a light to make sure its 15 degrees .
i have all those stickers all over my rb20det
it pretty much liek those seals on panadol cases i guess LOL
oi why is the a mitsubishsi (cant spell) symbol
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
