Just for a laugh.
1985 honda civic
890kg
1.6l DOHC ZC (not vtech yo) jap spec engine implant. 130HP at the crank from factory.
Mods: Extractors
rev cut 7500
15.5 down at WSID
100HP atw (75kw) lol at R31 club dyno day
Don't have it anymore.
My friends setup
R33 GTS
Rb25DE
-6-3-1 Custom Extractors > 2.5" Exhaust > Oval Muffler at rear
-Pod Filter in fibreglass box with a S/S intake pipe with factory AFM
-Apexi PowerFC
-GTR Injectors ( i think he said , not sure about that one)
-111.5rwkw / 149.41rwhp
VL Calais
RB30E
-6-3-1 Extractors > 2.5" Exhaust > single Oval Muffler dumped at Differential
-High Flow panel filter into custom Twin Throttlebody setup
-Tuned and Chipped factory ECU
-93rwkw
  • 1 month later...
  • 3 months later...
  • 1 month later...
ok, well i will list my 2 natro cars that i have had on the dyno (neither skylines though). will scan dyno sheets when i find them.
2000 n15 SSS pulsar
genie extractors
2" press bend system (which i want to get redone because it is just one we bodged up 1 arvo) with 12" centre resonator and lukey muffler (not a cannon)
k&n panel filter
fuel - dunno. probably 91 octane. can't remember
112hp atw (approx 84kw)
2000 mitsubishi magna (3.5L manual)
first run: 100% stock, rear muffler was a cannon, but rest of the piping was stock
159hp atw (approx 118kw)
second run: pacemaker extractors, 2.5" redback centre system (cat to rear axle), 2.5' lukey rear system k&n panel filter
170hp atw (approx 127kw)
1999 magna (same as previous one, manual 3.5L)
never dyno'd, but felt more powerful as the previous one had been thrashed a fair bit.
redback 2.5" exhaust
14.8 at willowbank with 2.18 60ft time
just found all my dyno sheets, etc
pulsar
first magna (and people say that you can't get a smooth dyno graph from a stock ecu, LOL)
second magna drag slip
Once I get my extractors I hope to get them installed and tuned and get some power figures up
The setup will be as follows
1992 E-HR32 GTS
RB20DE (Automatic)
COBY 6 -2-1 (2.5 outlet) to standard cat then 2.5" exhaust back to a canon muffler (loud)
Large K&N pod filter on stock intake piping (will modify later)
R33 series 2 - 4SPD Auto box (re4r01a) Which has a Stage 2 modified valve body
R33 series 2 torque converter
Advanced timing
Always have run on 98 octane premium Shell or caltex fuel
Suspension and braking below:-
Complete nolathane bush kit
Japanese Aluminium adjustable front Strut brace
Pedders Larger rear sway bar
Pedders sportsrider lowered suspention all round
R33 N/A Complete rear brake setup (4 stud)
R33 GTS-T slotted Front Rotors (re drilled to 4x114.3 pattern)
R33 GTS-T - 4 piston Front calipers (gold painted)
17" SSA wheels with 215/45R17 rubber
Looking at between the 100-120 Rwkw mark hopefully
2005 VZ SS ute
5.7l GenIII
4spd auto
cold air intake
Pacemaker extractors
HSV hiflow cats
2 1/2 inch stainless twin system with rwc muffler
LS1 Edit
239.9rwkw at aussie mufflers dyno
its running rich in the top end for towing duties, If i where to lean it out and get a retune, it would make about 260kw.
  • 1 month later...
  • 1 month later...
Just an update, had new exhaust put on the car, went from 137rwkw to 152rwkw, so i'm finally making 200hp at the treads.
Went back for a Retune with the new exhaust, I am now making 154.6rwkw (207Hp) as far as I know it's the 2nd most powerful N/a RB in Australia.
nice!! goes to show that if you invest $$ into an N/A RB you can still make some good N/A power! Do you have a dyno graph? I'm interested to see visually what the power delivery is like. What's the torque like down low being that it's an RB30/26, I'd expect it to have some nice bottom end.
nice!! goes to show that if you invest $ into an N/A RB you can still make some good N/A power! Do you have a dyno graph? I'm interested to see visually what the power delivery is like. What's the torque like down low being that it's an RB30/26, I'd expect it to have some nice bottom end.
This one doesn't have the torque curve on it but it sits almost flat from 2000 to about 6000rpm at around 350Nm.
  • 4 weeks later...
Not for long :down:
Nice graph though, would be really nice to drive, mines the same but a bit of a gap down low and it keeps climbing up top (more duration cams).
If you gave it some mild cams i reckon you could easy net another 15-20kW from it (but atm it looks like it would have beautiful drivability)
  • 3 weeks later...
  • 3 weeks later...
It's not mine, but my cousins manual MR30 with RB30/25DE made 144.6rwkw with a Haltech, injectors, 6-3-1 extractors, 2.5" exhaust and a K&N pod
Never owned a Skyline, the only car I ever put on the dyno was my Scorpion with extractors, a Weber, 2.25" exhaust and 5 speed, it made 67rwkw :huh:
Edited by jwebb2876
Rb 25 NA standard internals; nvct; 256 -degree Tommie cams; custom plennum with Falcon T/B; custom 6 into 3 into 1 extractors(no cat); Autronic set at 22 degrees-164 rwlklwts at 7600 rpm on Jakes Dyno( ACT ) in clubman sportscar road registered and 720 kgms
Engine:VQ35DE
Car: V35 Skyline Coupe
Mods: Z-tube and pop charger, Plenum spacer.
Power: 177rwkw.
Putting the Exhaust Headers on monday and a grounding kit. Will do a new Dyno run sometime next week. :bunny: Hopping for 185rwkw
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
