1998 EL Falcon
NA6 4.0L
lots of headwork, big cam, 3" exhaust, Wolf V500, ICE ignition, CAI.
198.9rwkw
That's a good figure man, any vids?
I'll have to post up some figures when the LS eventually gets tuned
  • 7 months later...
2007 V36 370GT VQ37HR 3.7L V6 5SPD AUTO
Modifications:
Cat-back exhaust pipes
Hi-flow panel filters
Apparently car runs rich from factory, bit more power to squeeze out of it if I can lean of the a/f ratio a bit
Stock Power run done close to when I first got the car for reference:
Hey mate, just wondering if you had the 180km/h limit when you did the dyno run as you have not mentioned an a/m ecu, if yes what gear was the run done??? cheers
By the speed, 3rd automatic.
4th gear will be in the limiter.
  • 3 weeks later...
Naturally aspirated RB26/30 R31 Skyline build-
Nitto high volume rb oil pump
Nitto h-beam connecting rods
Nitto crank collar
Nitto high compression custom pistons
ACL Race bearings - mains / connecting rods
ACL Race ProSeal engine gasket kit
Brian crower 1mm oversize valves
Ross metal jacket balancer with cam / crank trigger kit
N1 water pump
Nismo low temp thermostat
Oil restrictors
Camtech RB26 camshafts
Camtech valve springs and titanium retainer kit
Custom made ITB setup
XSpurt injectors
Heavily ported cylinder head
Link G4 Storm ECU
Genuine Nissan front / rear seals, idler and tensioner
Custom Gates belt
IGN-1A race coils
Dyno sheet - Mild Tune (will push it a bit later when its proven to be all well)
Engine torque is that divided by the diff ratio. 3.7 in this case
Annnd its on a hub Dyno hence the power curve "interuptions", if it was on a roller it would be smooth as silk.
  • 1 month later...
Nitto crank collar
N1 water pump
Oil restrictors
XSpurt injectors
Link G4 Storm ECU
Custom Gates belt
IGN-1A race coils
Post up a sound clip or vid, I wanna hear those ITBs :yes:
  • 2 months later...
So yer only took me a year to get around to it. Cam only through a stalled auto ;)
  • 7 months later...
  • 4 weeks later...
Hello, I have a 1998 R34 coupe and im having some weird problems.
The other week i got in to drive it and when i unlocked it problems started,
1. The tacho and speedo dont work,
2. The bell chime for door didnt chime,
3. The interior light stays on,
4. The passenger door wont lock with the button on the remote or drivers side panel.
It still starts and drives fine,
I disconnected the battery and reset the ECU which worked, but then it happened again and again now that trick only works sometimes.
Any ideas thanks
  • 4 months later...
  • 3 months later...
  • 1 month later...
R32 GTS25
RB25DE (small port non VCT R32 RB25)
CAI
Fujitsubo extractors. 2.25 straight through exhaust.
Mild port - exhaust side only.
Poncams.
Tomei cam gears (0 deg on both was actually the sweet spot surprisingly)
Nistune.
98 octane.
158.7hp atw.
Tuned by Matt Spry.
Link to dyno sheet below.
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-xtp1/t31.0-8/11062004_1013167325369234_3421555629321155321_o.jpg?efg=eyJpIjoidCJ9
  • 7 months later...
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
