  • Replies 42
if u get larger rims you will run a lower profile tyre, and they generally give better feel in the corners due to smaller/harder sidewalls.
however, i have found a better quality narrower tyre will probably offer better grip, unless the difference in width is huge. (this is massively general statement since we arent talking about specific tyres)
depends on if it is for street or strip?
strip you want a wider tyre on the rear, but not a low profile.
street you want a lowish profile tyre. if you go too low profile you get a rougher ride and they tyre won't soak up the bumps. so on rough roads it will skip around a bit more.
wider tyres only help with traction. once you get to a point where you aren't losing traction a wider tyre just adds ressitance.
not a chance.....cheap wide tyres FTL.
Apart from the fact that the tyre compound is what gives the grip, wider tyres will tramline more, aqua plane in the wet.
And don't forget that on the same cars a wide tyre and a narrow tyre have exactly the same amount of rubber on the road.
I've been there I had 265 falken 326s years ago and they were disgraceful
damn straight to that..
i got like 8inch fronts, 9inch rears on 17inch. Tramlines a fair bit .. But then again my fronts dont have much thread left, and i got a soft compound rubber( advan rubber :P )
Will get new tyres for the fronts n see if that changes. Most likley it will.
Edited by siddr20
If given x amount of dollars, would it be better spent on quality tyres on stock rims, or upgrade the rims, and get wider tyres to increase contact patch with less quality tyres?
On your criteria, I'd say go with nicer tyres on current rims. Money you spend on buying bigger rims is money you're not spending on tyres.
Take my Z for example (since I only know these prices off the top of my head). I could go to heavy-as-lead 19's with Nankangs or Wanlis or some other dodgy tyre on them from the Temple of Chrome for around $2800...or buy a set of Michelin Pilot Sports in the OEM size.
Michelin Pilot Sports vs Nankang NS2s? Even with the Nankangs being 30mm wider its not a hard choice, if you're talking about grip.
...And don't forget that on the same cars a wide tyre and a narrow tyre have exactly the same amount of rubber on the road...
I dont really understand what you mean? I would think that wider tyres would have more rubber on the road?
I was looking for the best compromise, in a road wheel/tyre combo. I think that the stock r33 wheels are quite heavy (21kg) and not that wide (6.5inch). So was even thinking of moving to a light weight wider rim. Just dont know what is the best package. Money spent on just the tyres and keep the r33 rims, or moving to a light weight rim, wider, but less quality tyres.
R32 gtr rims good compromise?
Edited by lastlineofdefence
Cheaper tyres, offer cheap grip. Cheap grip is SHIT.
I have the same Falkens someone else mentioned earlier. They were on the car when I bought it. Seriously, if I wanted to KILL someone, I would put these tyres on there car.
For lack of grip in a cheap tyre, I can spin 1st+2nd, and not leave a mark on the road, nor any smoke. How's that for a lack of grip?
Put on grippy rubber!
My old commodore ran shit tyres when I got it, I was going to put mags on and run very good rubber, but decided in stead, to save the $2500 on mags, and just buy tyres. $500 later (It's a family car!) and the car behaves totally different. ALOT more grippy.
Just spend your money on the BEST gripping tyres possible (This does NOT mean the most expensive tyre! Read up on the thread above about good tyres)
tramlining isn't just caused by wider tyres. the individual tyre can cause it too. on my 180sx it would pull when you hit bumps. put new tyres on and it stopped doing it.
There are also multiple other reasons for tramlining. Lower profile tyres (not necessarily wider) will also be more prone to tramlining, due to there being less give in the sidewalls. If you don't have your pressures just right (too high or too low) tramlining will be an issue, not to mention incorrect tyre wear & poorer grip levels. Things like camber settings etc will also have an effect.
I was having tramlining issues on the front of my R33 with 225/65 18's & found that if the pressures were much up above 36 I had major problems. I then dropped them to 32 & thought it was better, but it was still there & i started to find the outsides of the tyres were wearing a bit quicker than they should have been due to under inflation & I didn't have as much grip as I would like.
I Now have them at 34 psi & there is virtually no tramlining at all, even on heavily rutted sections of road, & the grip & handing is greatly improved. I'm still to try them a tad higher & lower than this, but this seems to be around the optimum pressure for me.
As far as upgrading the rims is concerned & going for cheaper tyres I'd also say forget it. If you're gonna put something like 265's on the back & can't spend at least $300 a corner on a set of Hankook K104's (The only tyre on the market in that size which seems to be an even blend of cost, performance & durability) then stick with the stockies for now, put good rubber on & start saving for next time.
Check out what people say on the tyre thread too about different tyres.
Edited by JazzaR33
Not if everything else is kept constant.
The only thing that changes is the shape of the contact patch.
generally with tyres you have
grip, cost, longetivity
pick 2.
17x8 and 16x8 (R32 GTR) are good sizes. 235/45/17 has a massive range of tyres, and they are quite well priced due to the massive popularity. call a tyre shop and find out how much for a set of decent tyres. youll have to research what decent tyres are, and it will depend on your taste and intended purpose. you can pick up 17x8 wheels pretty cheap 2nd hand.
225/50/R16 bridgestone semi slicks are cheap - they are a control tyre for a racing class, was going to put these on the 31. (16x8)
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
