Not sure if this is the right place to put this but..
Ive read somewhere that petrol loses its OCTANE level after a period of time.
So approx how long does this occur? Is this true?
For example I fill up the car with BP Ultimate 98RON, how long will it take to "expire" and lose its "98RON" properties?
Is it bad for the car if there is fuel in the tank from like say 6 months ago?
Cheers
https://www.sau.com.au/forums/topic/138836-petrol-expire/
I'd leave fuel in the tank, an empty tank tends to rust.
And some light reading on the subject:
http://www.chevron.com/products/prodserv/f...detecting.shtml
http://www.virginiawind.com/tips/gasoline_stabilizer.asp
http://www.challengers101.com/FuelStorage.html
The last one is the most generally informative. I was looking for a deterioration duration curve [time vs decay] but couldn't find one.
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2585746
less wh0ring more explaining.
maybe around two weeks it would drop a bit of its just sitting there in the tank?
Hmm interesting.. thanks Paul! :)
Mate works at an Audi workshop, they had a car sitting for 2 years and someone tried to start it. The petrol had thickened and needed new lines and pump as they were all clogged up.
lawl two years
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2586284
a friend who used to run a local servo a few years back said it drops octane even while sitting in the tanks at the servo. so servos that dont do as many customers, fill up less often, are likely to have lower octane fuel than a busy store than fills up reguarly
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2586327
Official word from Shell is that their fuel will be stable if stored up to one year, as long as the storage conditions are "adequate" - ie the containers are full to minimise exposure to air, tightly capped, out of direct sunlight, and under 27°C.
underground tanks at servos don't even fulfil those requirements. And vented petrol tanks in cars that get nice and hot sitting in the sun and cool down again at night certainly don't, so the fuel deteriorates much faster than these optimum storage conditions in Shell's literature.
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2586384
The deterioration of fuel is or can be brand dependent. If you read any of the links in my previous reply, it appears that the length fuel can be stored also relies on the preservatives each company uses to increase the shelf life of their brand. I don't know which ones are best, but I wouldn't trust any of them. Its an easy question really: Whats cheapest, a new tank of fuel or an engine rebuild?
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2586431
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
