  • Replies 45
I had a turbo blow on a GTR.
Never compression tested before the turbo blew, but after it blew it started having severe blow by.
Compression tested less than 125psi on three cylinders that corresponded to that turbo and 140psi on the three that didn't.
I assumed it was related but can't back that up.
Have always been scared of blowing turbos since, yet have been informed by many people running single turbo's who have blown turbos they had no dramas.
Compression test for starters, will help answer your question.
Yep.. I have posted on here a few times about this type of thing.
Some don't believe it, but I have seen it happen enough times to know it does.
Only with Ceramic turbos.. and no idea what causes the dust to suck back into the engine. Causes some nice damage though and only to the 3 cyl that the turbo was on. I'm talking large gouges in the bore.
I was always careful with my GTR's with stock turbos after seeing this.
dude I'd be leaving the car off!!!!
And pulling off the head to check for damage maybe a compression test would be a good idea. before taking off the head.. :)
Have you looked at the turbo?
My car made a bang and ran like poo it was just blowing smoke and run like a pig above like 2000rpms tuned out to be a intercooler pipe came lose.. made heaps of noise!!!
Hope all ends up well...
Hey guys, got it fixed today, got a new high flowed gcg turbo. The wheel was shattered, they took it out from the middle thinggy in the exhaust.
i went from a 276 hp to 311 hp, 206kw to 232.2kw
I am very happy, the car is really powerful
All thats left is the exhaust all the way through and the injectors
Edited by the_game
just throwing ideas out there:
- 20psi of exhaust back pressure at full boost in your GTR (guesstimate)
- exhaust wheel dies, jams against turbine housing
- exhaust back pressure spikes horribly because total exhaust flow from those 3 cylinders just took a huge dive
- big back pressure = big ping, massively hot exhaust residuals left in combustion chamber on next compression stroke causes pre-ignition
- 3 cylinders get blowby, ring damage etc
i can't really think of another reason that the rings and pistons would be damaged if a turbo let go in a GTR. it would be very improbable that ceramic dust/chips/fragments would somehow make their way back into the combustion chamber through the exhaust runners and valves. especially for it to happen equally on all 3 cylinders.
I have to disagree. That engineer can say what he likes, however you still have either an internal or external wastegate which limits the exhaust manifold pressure. Although this pressure would be higher than previous.
You can still get cermaic wheel pieces or dust swept back into the cylinder. Especially during valve overlap when your exhaust manifold pressures are much higher than your intake (increased if your turbo is broken: greater pressure differential).
While your engineer is correct that increases in EMAP will increase residuals during the next cycle, its unlikely due to the fact your wastegate would still relieve the EMAP close to normal operation and the compensation by your ECU is still most likely within its limits assuming your lambda sensor is in and working for feedback control. :laugh:
I can think of plenty of other reasons why a turbocharger would damage your engine. Mechanical contact from compressor pieces. Hydraulic compression of fuel from running too rich and incomplete combustion outside of ecu compensation (which is limited)....
Edited by AndrewD
At the risk of sounding simple...
The question was:
- 'resulted in a blown engine'.
He did say from stuff going inside the engine, but I'll take one step back from that and say, who knows exactly why
- BUT
The answer from experience seems to be, and I'm sure others will back me up:
- On GTR's that have blown stock turbos, it is quite common to have failure on the three corresponding cylinders.
I never looked too much into why, so at the same time, it may only be the case for twin turbo's... could that be a possibility?
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
