Hi All
Got a few questions before I get stuck into my brake upgrade.
I have bought some R34 Gtt front calipers (310mm rotors) to put onto my R32 Gtst.
Will they fit straight on without mods?
Is my brake bias going to be affected?
Thanks,
Russell
https://www.sau.com.au/forums/topic/139091-some-technical-questions/
The only way to find out is to bolt it on and see.
But on the face of it, bias wont be overly affected. The R34 calipers run the same sized piston as the R32/33 etc so the only real difference is running the bigger rotor that still fits inside the 16" wheel.
As for bolting straight up. You will find that the R34 caliper uses bigger bolts so will need to drill out your hub.I havent done it personally but understand its not that big a job
  • 3 weeks later...
Has anyone done this before?
Am I best to drill out the hub and fit the larger bolt or can I get a hub off an R34 skyline and fit that?
I don't want to drill them out and then find out that there is not enough meat around the hole and make it dangerous.
I've done it. As roy said all you need to do is drill out the holes.
I've had r34gtt brakes on my r32gtst for a good 3 years now with no problems. You're only increasing the size of the hole by 2mm, 16mm-18mm from memory.
Yeah I had read 18mm somewhere but I wasn't 100% sure.
Did you grind off the shroud behind the disk? Also did you just drill it in place or did you use a proper drill press?
Thanks for the info.
The backing plates are untouched on my car. The fit was perfect.
I did the dodgy method and drilled on the car. It took 2 people to hold it all steady and drill it though.
Hmmm.. The backing plate fouls the new larger disk. I'll grind it off anyway for better cooling.
I think I'll just drill it on the car too. I'll probably stuff something up taking the hubs off!
Now I just need to get the correct size bolt because the callipers I bought didn't have the bolts! Anyone have some? Do you know what size the bolt is?
For the bolts i just took an r32 caliper bolt for length and the r34 caliper for a sample to get the right diameter/pitch bolt. Shame the place i used to get all this shit has closed, damnit!
Then measured the bolt to get the right size drill bit. though 18 does ring a bell.
I am in the same position. Own a Cefiro and have R34 calipers and rotors.
So just drilling it out while they are still on the car works..... sounds alright then.
What about the rear calipers? Is it the same or is it just the front that use the bigger bolts?
The bolts came with the brakes except for one :( *sigh so now I need to find one bolt aswell. Anyone know where you can pick these up from?
  • 3 weeks later...
I still havnt finished it. Ive measured the size of the R34 bolt and its 14mm but Ive been to bunnings and Repco but they dont sell 14 mm drill bits. The biggest drill bit they stock go up to 13mm.
Where can you get 14mm drill bits from? I also measured it in imperial which came to around 3/5" which again I could not find.
THIS IS SOO ANNOYING. Might just sell the calipers and get me some R33 calipers.
Any help will be much appreciated.
=> Russman, how are you goin?
I'm gunna try and get the bolts this week. We'll have to go to a fastners place. Bunnings and repco/bursons don't really have that stuff. the R32 bolts are 48mm long and I'm taking in the caliper to get the right thread. Make sure they're high tensile stuff. I didn't really think about drill bit size... what are the original hub hole size?
Don't sell em. shouldn't be too hard...
Just spoke with a friend about this and he said I should explore the option of a "Helli Coil" or "Heli Coil" Dont know exact name/spelling.
But basicly take it to Repco or a fabricator or something along those lines and ask for one.
We all know now that the original bolt and hole on the car is smaller then the new bolts and hole on the new calipers. My friend said these Heli coil things are basicly a plug that you will be able to thread into the new caliper which is hollow and has a thread on the inside.
Thus you use your old SMALL bolts which will then be able to screw into the new calipers..... Sounds interesting and obviously get it in high tensile stuff so it wont break.
Will check this out tomorrow hopefully. Will let you know when I have got around to it. :P
Will check this out tomorrow hopefully. Will let you know when I have got around to it. :D
I thought helicoils were used basically when you stuff a thread and it gives you a new thread, not to make a thread smaller?
Anyway I got the bolts from a fastners place but I got 50mm bolts and that doesn't include the head so it's about 58mm not 48 that I need so I'm going today to get the 40mm bolts which should be right.
edit: Got my bolts now, M14 x 40. just need to get some brake pads and a 14mm drill bit and I should be all set!
I've finished one side and all is going well. I'll be doing the other side on monday and plan to put up a DIY here on SAU.
Hows it going meanman?
Havnt done anything :P have slacked off on this. My bad, did buy Cusco coilovers and fitted them fine:D
Where did you get your 14mm drill bit? Where did you get your bolts from? im missing one.
If you can get a step drill it will stay pretty much on centre , self aligns .
Cheers A .
I doubt a step drill will have a long enough step to drill one size for the width of the hub.
Havnt done anything ;) have slacked off on this. My bad, did buy Cusco coilovers and fitted them fine:D
14mm drill bit and bolts I got from a bolts and fasteners place. drill bit cost $25 and bolts were like $15 for 4. You will need a M14 bolt that's 40mm long. Good luck.
Anyway I'm all done and drove it around last night and it's all good. I'll post some pics when I get some time.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
