Can any one help me i have been told that the vg30 turbo off the single turbo 300zx will fit on to the RB25 det neo and that its a good upgrade for a bit more power. Has any one done this or no any one that has and are thay happy with it.
Thanks Ryan
https://www.sau.com.au/forums/topic/139387-vg30-turbo/
I'd say that getting a Sliding Performance high-flow or a Sydneykid group buy GCG high-flow would be a better choice.
But as far as I know , they are slightly larger than the RB25 ones and bolt up with minimal, if any modifications.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-2597608
Thanks Ryan
One answer... No. :mad:
If you run the turbo off a 300zx you will have to change dump pipes etc.
If you were to run a turbo off the later model VG30DET's from the Leopars/Cima's etc then you don't have to change anything; but the turbo's are not matched with 'performance' in mind. The run nothing more than an RB20DET turbo's guts with larger turbine and comp housings to make it lazier so that it gives smooth progressive power for their cruisers..
The by far best T3 Nissan turbo is the R34 GTT Turbo, it runs the larger OP6 turbine housing as the VG30DET turbo does but a nice chunky compressor wheel. Not a piss fart RB20det compressor wheel like the VG30det turbo does.
And no... its not worth the upgrade for 10rwkw. :mellow:
Highflow the turbo; GCG if you want maximum response with good power, the slide turbo if you want to save a few $$ or see if you can track down a nice little HKS GT2530.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-2597812
  • 1 year later...
Sorry to resurrect an old thread, though I am in the throws of purchasing an R34Gtt turbo to replace the VG30 turbo currently on my RB20DET.
I am trying to get rid of some of the lag.
Will this help given that the R34Gtt shares the same exhaust housing as the VQ30?
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3457832
If i'm not wrong the VQ30 has a bigger exhaust housing to the R34 GTT turbo
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3458086
I'm not sure - I guess that's what I am trying to figure out (as I want less lag and I am told that a larger exhaust housing = more lag). Cubes (above) has written that they are the same and Manwhore (on another thread) agrees.
Edited by Birth
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3458165
VG30 and R34 GTT turbine housings are the same.
The R34 turbo has a slightly larger compressor wheel that is possibly lighter due to the material it is made out of.
It will punch harder when it comes on as a result.
The R33 S2 turbo really is the best pick out of the std turbo's for the rb20.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3458588
Just a question, turbine housing and exhaust housing are the same thing or different? I'm sure the VG30 single turbo is definitely bigger than the R34 turbo in certain ways, thus giving me more power as proven on dyno. Have a friend with a high flow R34GTT turbo put on dyno and my hi flow VG30 turbo on dyno, i have about 10 rwkw more. Not much of a difference though i feel.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3464337
ok, I have bought an R34 turbo with the OP6 exhaust housing as it is a bargin. I am looking at acquiring a new exhaust housing via swap or buy - what should I be looking for, a. one from an R33 turbo because that is what everyone is telling me to buy because the ex housing is smaller than the OP6 or an RB20 housing because that is even smaller than the R33 housing, but the R34 compressor will off-set that with better flow?
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3465451
  • 4 weeks later...
To finish this converstation off - I have installed my R34 GTT turbo. The swap itself was obviously simple. I think that the R34 turbo is better - there is more boost early on and the car feels alot more drivable, though I do miss the surge of power that came on with the VG30. Don't let me be a sook though, if you have an RB20 and you are looking for a cheap upgrade neither is a bad solution (the VG30 is in my opinion certainly better than the RB20 turbo), though I think that the R34 is the way to go.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3509663
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
