OS Giken cross mission gearset, or a PPG straight cut dogbox. The stock box can even last for a 1000HP, but is all a question on how you load up the gearset, do you launch big at the lights, or do some engine breakin. if you could apply load steadily, id sya it would hold a 1000HP. I broke mine with a little more than stock power ( about 350-370HP), sinc ei have built my car i have the cross mission gearset, and redline oil in it, and hast complained yet (and i abuse my car). I also run a EXEDY tripple plate clutch with full face sprung hub plates and a heavy clamp load Pressure plate.
https://www.sau.com.au/forums/topic/139583-stock-gtr-box/#findComment-2602601
This is great timing cause im looking at doing my gearbox aswel
OSGiken retails for 3k for the 1,2,3 set, plus fitting etc
PAR want $5500 for them to supply and fit their 1,2,3 set into my current box
Havnt got a price from PPG, but would really like to know if they're pricing is competitive or not
The OSGiken seems the way to go so far pricewise, but are they straight cut or helical like the OEM gears?
There's another thread un this same section about stock boxes being rebuilt and the prices for them are around $1200 even with some work done by the owners, so at a guess with labour included, it could be almost $2k, which to me, it a waste as it will just be a freshened up box, not a newer, tougher box, and id just spend the extra bit and go OSGiken :)
https://www.sau.com.au/forums/topic/139583-stock-gtr-box/#findComment-2602646
I've just rebuilt my box with an OSG cros mission set. I'm seeing around 550 awhp through a 2.8L. I won't have the chance to judge for myself until I'm back in Oz early next year.
I made the choice after speaking to Leewah who runs a hell of a lot power than I ever will. He told me a while back that so far his gearbox has lived up to the abuse he has dealt it.
Dog engagement (helical or straight cut) gears will in theory take more power as the gear face can be widened to take up the space that the syncros once occupied. This comes at a price of increased noise and vibration and an alternative gear changing style, however.
Edited by Gav
https://www.sau.com.au/forums/topic/139583-stock-gtr-box/#findComment-2603532
And ready for more HP.....correct?
Otherwise, why would OS make them?
......unless they're solely for changing ratios - but even if thats the case, why not upgrade at the same time ? :)
Yeah, i've heard of figures around 800hp. I the Racepace GTR has around that power and runs the OS gearset...
https://www.sau.com.au/forums/topic/139583-stock-gtr-box/#findComment-2605446
Going through this now and im 99% set on a PPG box.
5 speed dog box with 1000hp mainshaft and they give you the option of the standard input shaft or upgraded hollinger style for the same price. Around $9000 but will hold the power.
Only downside is the noise they make.
https://www.sau.com.au/forums/topic/139583-stock-gtr-box/#findComment-2605893
Is $9000 what thwey quote for the PPG straight cut? i had imagined it would be like 15k. I am currently building a full drag spec engine, but i thought that a straight cut dog box would be out of the question due to the wads of cash they ask for it. I would just be using my crossmission gearbox and propbly bloow it to bits, mow i just might look into buying that gearset
https://www.sau.com.au/forums/topic/139583-stock-gtr-box/#findComment-2606226
My mate has a dogbox in his gtr and it sounds mean similer to a electric toy car actually i havnt herd alot about the giken stuff
just to clear one thing up. its the straight cut gears that make the whining noise not the dog engagement. they are only responsible for the 'cha-chunk-crash' as you change gears. i make this distinction as people often assume all dog engagement boxes are straight cut (not the case) or vice versa that all straight cut gearsets run dog rings (also not the case). you can occaisionaly see straight cut/syncrho boxes and some times helical cut dog engagement boxes.
for a car that does street driving an upgraded synchro/helical box is the way to go.
https://www.sau.com.au/forums/topic/139583-stock-gtr-box/#findComment-2606365
I've got the PAR gearset in mine, with what i believe is a very practical street option, by way of having a straight cut 1st, 2nd & third to handle the punishment & a beefed up Helical 4th but still with Synchro Engagement, they make & supply their own upgraded 1-2 synchro hub, for 3-4 the stocker is oK.
That way you have the strength but still the smooth drivability. uses your stock 5th & reverse gear.
i think he said it will handle 1000hp
sounds awesome too!! (like driving through three gears in reverse), then pull 4th & back to quiet cruising
cost was $5,600
https://www.sau.com.au/forums/topic/139583-stock-gtr-box/#findComment-2607427
just one question:
how hard is it to go into gears in low revs for a dog box?? i do a bit of street driving, so i dont really want a harsh box...noise is fine with me as the car is loud any way....
also, is there any options for street/circuit car which only has around 400awhp?? there is a thing called budget for me,lol..
https://www.sau.com.au/forums/topic/139583-stock-gtr-box/#findComment-2640955
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
