Hi All,
I thought i would come to the experts. My RB20 is coming along nicely with a APEXI AVC-R boost controller, fuel pump, coil packs, air induction and full exhaust system and I love the results. On the weekend however I put on a new BOV and I noticed my oil pressure idleing is just above the zero and when boosting wont go above 2 (which is a quarter of the maximum 8). Why is this and would it be due to the BOV? Also how can this be tested or fixed.
I appreciate any help as I have not come across this before.
https://www.sau.com.au/forums/topic/139833-oil-pressure-low-on-my-rb20/
Hi All,
the senders normally whack out... but in my case i think my oil pump is screwed because the top end is making horrible noises.
I have an Autometer gauge which has replaced the stock oil pressure warning light sensor. It reads in PSI so i dont know if it will be any help to you but i use a 10-40 Motul oil in my RB20DET which is basically stock, on cold start i get around 60-70psi of oil pressure at idle, after around 5-10mins of driving it will read around 6-15psi of pressure at idle and rise to a max of around 45-50psi at 3000rpm when hot.
stupid question, but will pressure vary b/w oil?
i just changed my oil from a motul 4100 turbolite 10w-40 to motul 8100 xcess 5w-40 and ive noticed a pressure drop once the oil is warm. Previously it would sit close to 4 on the guage and no it doesnt rise above 2 once warm..
should i get a different oil?
engine is an rb20det btw
i got custom gauges put in, and my car on 15-50 mobil one, reads about 70 cold, and about 40 @ 3000rpm, but ideling it sits between 20-15 psi should i be worried can suply photos.
Note: mine did the whole read jsut above zero never gets above 2 thing, so i went out a put customs in
- to answer your comment, get ur mechanic to do an oil pressure test on it, and i would recommend getting aftermarket gauges, and leave the BOV out of it.
55yko
Edited by 55yko
as long as the oil pressure warning light is not illumminated, then all is ok
the stock oil pressure sender is dodgy on all nissan imports and won't give you anything even close to the correct pressure...
i recently installed an aftermarket gauge in my glovebox and find that:
when warm at idle it sits between 1-2bar
when warm and cruising/driving the oil pressure varies with rpm (can't see this on the stock gauge) and sits up around the 3-4bar area
obviously pressures are much higher when the oil is cold
gauge cost me $20 (ebay)
gauge cup $5 (ebay)
sandwich plate $30 (justjap)
not a bad investment and is hidden in the glovebox nicely :(
cheers,
Warren
My stock guage is all over the place.
Some days it reads like it should, others barly above the 0.
Its always been like that though, even with the old motor.
Quite funny actually as I've caught it going from crappy to normal.
Cruising along at 100km/h, oil pressure sitting on around .5 then all of a sudden with a sharp jolt the needly flicks up to just over 4 which is where it sits when the guage is playing nice, sat there for the next few days then decided to go gar gar again.
Wouldn't be too concerned. RB20's are cheap anyway, drive it until she starts making funny noises.
Guilt Toy.... I'd say your lifter problem was likely attributed to poor oil pressure. As I'm sure you already know. :P
Thanks for all your help everyone. I'm just going to drive the bloody thing and have a mind set that the oil pressure gauge is faulty. If it goes boom I will just chuck a RB25 in it anyway as I planned on doing next year anyway.
hi im wondering if anyone could help me on a simalr topic?
i have a problem with my rb26 regarding with the oil pressure, everytime i hit high revs or hit boost the oil pressure goes down to 0 and the warning light will turn on.
if i drive normally without going over 4-5000rpm its ok, the pressure doesnt drop and the warning light does not turn on.
i would appreciate any help thanks.
cheers,
cheers,
Jesus, stop driving it on boost. High revs + no oil pressure = boom, as said above the warning light almost always does work. It could just be low on oil and getting starved under decent Gs (accel, cornering) check the level and if its really low do a change, otherwise it could be the pump itself but definately check it out before you do any more damage. Also there can be problems with excessive oil getting to the head but I don't really know much about this topic. Probably be wise to check the oil and see if theres any bearing matter in it as well (silver sparkles)
Edited by Rolls
will the engine die straight away if your on boost with no oil pressure?
or is it more of a wearing of the engine until it dies?
i think ive been hitting boost with no oil pressure
hopefully its just a tired guage
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
