When are you gonna get Dyno'd? I'll talk to Robbie for you and see if you can get it done for cheap. All you need is power runs, don't you? I've been meaning to get a base power run for mine before the new engine goes in.
Yeah we went to adrenaline, just rocked up to try our luck but he said there pretty busy for the next week (till thursday)
So might try and book it in for saturday. Yeah just need a power run to see where its at
just had adrenaline retune my car with new turbo installed, must say rob does a good tune each time! great results as well verry happy will be much more fun at the strip this time around when the dam rain pisses off!!!!!!!!!!! hopfully the 25th of this month will see us all out there haven a few runs. them all these bloody holden and ford lovers can bowe down to the rice burners!!!!!:worship: ha ha ha ha jokes jokes there are a few fast ones around thats for sure, stupid xr6t! little modes and big power out :banana:
ill be in for any cruize any time!!!!!!!! any excuse to go for a drive, and the tune ended up at 492rwhp so far a little more in refining the tune and should be maybe a little more in it. ran out of fuel in the injectors so that will be the next thing. car drives great so far so will be keen to do some 1/4 mile times. i got slicks this time and changed the rear diff ratios so should be a bit more fun
well that depends on what turbo your running at 18psi? still will be good figures, it will be more responsive than me on the road thats where is counts. not that mines a huge lag monster but the 3076r garrett i had earlyer this year was a ball tearer!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
