family friend, dads been mates with him since they were youngins. Hes been doing it a while he knows his stuff.
Ive been thinking about just doing a simple setup, water sprayer on intercooler, put some dry ice and water in it when I want to go racing. But Dont really need it lol
The temp drops across my cooler are phenomanal. On a hot day you cant even touch the hot side and the cool side is just a little warm. Stainless 3" pipes make it easy to feel the difference :)
Edited by 89CAL
The engine he built me lasted about 1,000kms, while rev limited to 4,000rpm and never running higher than 12psi.
When I asked him to have a look at it, he told me to get f**ked. $6k down the drain.
Its sitting in pieces under my house.
Will never get anything done by him again.
Edited by The Mafia
had a good run yesterday arvo robi33 you should have come along, had a run with the new corvette z06 and lets just say it was not fair.......... for his at least ha ha ah :whistling: as sson as i get the chance ill upload the video to you tube.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
