family friend, dads been mates with him since they were youngins. Hes been doing it a while he knows his stuff.
Ive been thinking about just doing a simple setup, water sprayer on intercooler, put some dry ice and water in it when I want to go racing. But Dont really need it lol
The temp drops across my cooler are phenomanal. On a hot day you cant even touch the hot side and the cool side is just a little warm. Stainless 3" pipes make it easy to feel the difference :)
Edited by 89CAL
The engine he built me lasted about 1,000kms, while rev limited to 4,000rpm and never running higher than 12psi.
When I asked him to have a look at it, he told me to get f**ked. $6k down the drain.
Its sitting in pieces under my house.
Will never get anything done by him again.
Edited by The Mafia
had a good run yesterday arvo robi33 you should have come along, had a run with the new corvette z06 and lets just say it was not fair.......... for his at least ha ha ah :whistling: as sson as i get the chance ill upload the video to you tube.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
