Yeah i all ready sent them an email Kingy getting the Advan Neova AD08's for the R32 and i'm gonna get them New Hankook Ventus R-S3 285/35R18 for the R33 as they don't make the ad08's in a 35 profile in 285's, mackay roads are to shit house for 30 profiles. They give these new Hankook's a good wrap they are a 7.8 and the AD08's are 8.4 on tire rack so i'll give them ago, slightly cheaper aswell.
Hankooks
Advans
Yeah I borrowed a guard roller and did them myself, turned out pretty good I thought, didnt crack any paint... Not bad for a first try :) haha
They are 265/35 rears, factory arms etc. Just lowered a little bit, probably an inch maybe slightly more.
Still tossing up between rear camber arms or just camber correction bushes, will have to decide and take it in for a wheel alignment sometime soon
Think the camber at the front isnt to bad so not sure if ill bother adjusting front camber
Yeah adjustable arms are nice to have, but if yours is a everyday driver i would go with camber correction bushes because aftermarket arm have pillow ball ends (rose joints) and depending on what brand u buy they tend to flog out a fair bit especially mackay roads. I nearly have the full ikeya formula catalogue on my gtr, they are awesome bits a gear but cost you a arm and a leg...if only i had a spare 2k for front and rear lower adjustable roll centre kits...you wanna sponser me kingy lol
I got a full time job sponsering my own :nyaanyaa: lol...
You would not believe what i got quoted for a light globe at autobarn yesterday... $345 and have to order it in gotta be kidding me...
Is there anywhere in town that sell HID globes off the shelf??
Yeah i done the rounds today only place i could find that stock HID were ashdowns in paget but they didn't have the right one. and were 180 per globe lol
Got a pair off ebay for 110 from melbourne. Hope its the right one so many to pick from.
So I had to roll the front guards on my car today, thought they werent an issue but chewed a bit of tyre turning into a driveway the other night lol so decided to fix it today.
Hopefully all good, didnt do much damage just put a very small dint where one of the screws from the drivers side inner guard hit the other part of the guard but oh well. Not a bad job and it was free
Bored, Thought I'd put photos of my first car up seen as I got a bit nostalgic posting a photo of the engine bay in Bens build thread haha
And what it decided to do on my 18th birthday:
Aftermarket lifters are a no-go in RB30E's
Edited by 89CAL
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
