Sweet as. Started editing some RAW photos yet?
Can make them look really good with just the initial processing in photoshop.
Post some up if you edit some :)
Like I said to you, I really wish we got more photos but that's just the way it went lol.
Yeah I have to get my FC Hako working again. The latest firmware seems to have screwed something out and it's dropping out. Was gonna have a look at everything at the drags but it kept dropping out early in the run
Got a thread uo in the for sale section but thought i'd throw it in here as a local sale wold be alot easier lol..
18x9.5 +20 BBS RG-R wheels
R34 GTR Brembo Brakes
PM for details
Cheers
Matt
Mmmmmm Brembo's haha
You gonna get your photo DVD from airlie? :P
That goes for all who were there to
Well have the Wideband in now:
Seems a little laggy (not to bad, half a second probably tops) but I dont know if it gets better as it gets hotter or if the gauge is just slow. The main point is the analog out from the gauge to run with FC-Edit so I can bring up the AFR's on the laptop and in map watch. Should make tuning alot nicer
Pacey: You might know this... Is there a way to bring up two map watches in FC Edit? I want to have AFR and Knock maps both up, but I dont think its possible......
Had a play yesturday but didnt really get anywhere.
This looks like much more then 2 degrees of camber........
Used some Turtlewax bug and tar remover on my rear pods to get all the tar off that the tires flick up. Works a treat that stuff
Edited by 89CAL
Lol looks closer to 5!
Yeah I think pedders may have dropped the ball on that one. My report said 2.1 degrees or something.... Doesnt look right lol.
Did a little playing around with my tune today. Trying to fix a funny spot. 5th gear foot down and it goes 13.2 then climbs to 14ish then back down, weird. Added some fuel to a cell that looked like it might be the problem but its still doing it so not sure what the go Is....
So got my new front cover for my turbo made up......
The thing sounds even louder then before! I thought without the anti surge slots would make it alot quieter.
Anyway the thing is so rich now I'm lighting up the night with backfires so will need to play with the tune on the weekend (10:1 AFR's atm)
Wheelspin in second easily now but, if it wheelspins in 3rd after tuning then I may have solved the problem with the HKS GT2835 KAI and its disapointing results in comparison with the Pro S
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
