HAve you looked at the 3.4l stroker kit? I know its a little bit more, but its good value if you can stretch a grand or two more.
By the time you by rods, pistons, rings, rod bolts and bearinigs, and balance you're around $3k - $3.5k
3.4L stroker has a new crank, rods, pistons, bolts, bearings and rings and is $5k. I think it is already balanced.
WHen you think about it, $1500 really isn't that much more for a torque monster. Plus you wouldn't have many lag issues.
WHERE the f**k u getting these prices from.... $3k for rods, pistons ect.... what are they beryllium ?? or are u buying these and adding on the miner tax ??
well..I just checked and the prices have dropped a little since i looked last. But pretty close..
GOOD Pistons & Rings $1400
Spool Rods: $700
Rod Bolts: $200
Bearings: $200
Balance: $400
Crank Collar & Fitted: $200
Total: $3100
Crank journals \ Block tunnels might need machining - $possible $500 - $1k depending on what needs to be done..
I'd even get the crowns of the pistons and the combustion chambers HPC'd. Price isn't too bad. Just need to balance after this is done.
3.4 Stroker, with all of those parts, already balanced with a brand new crank that is capable of high revs, is only $5k..
Then buy a GTR one day and transfer this bottom end to it... lol
To me it just seems like a better buy and more piece of mind.
I want to stick with the RB25. For what I want it to be, anything over an RB26 is useless. I'm not a racer, drifter or anything. Just want a safe motor and tune that has some balls that MIGHT have a chance against a SIL80 that will be around the streets shortly.
http://www.spoolimports.com/spool-engine-rebuild-kits/nissan-rb25det-rebuild-kit
Nissan RB25DET Rebuild Kit
This Rebuild Kit includes the following quality parts:
  • SPOOL Forged H Beam Conrods
  • CP or Ross Forged Pistons (Rings, Pins and Locks Included)
  • Cometic MLS Head Gasket
  • ACL Race Series Main Bearings - STD & 0.25mm
  • ACL Race Series Big End Bearings - STD & 0.25mm
With Ross Pistons - $1990
With CP Pistons - $2090
the rods come with bolts already dont need to buy 2 lots
She'll be a screamer. Can't wait to hear it on gate, haha. I don't know who is tuning it yet, he hasn't told me I don't think. But deadset, the turbo on it is going to suck small children in if he drives past a school or even a pregnant woman.
That's the kit I was looking at. Want to keep 2.5L, but the reality is that even the $2,000 for that is out of reach at the moment when im paying off stuff, saving for a house and saving for an overseas holiday on apprentice wages. The 33 is taking a backseat to more important things at the moment, but one day I'll get a rebuild kit, spray and tidy up the engine bay, and make the engine look pretty like my VL RB30
Then it will be 24psi of HKS fury pumping into that engine haha
is 24psi where the efficiency runs out ?? ur talkin bout the turbo u got on there now ay ??
im gonna hate goin back to apprentice wages :(
HKS GT2835 KAI
Bit of a let down ATM but trying to work with HKS to work it out
243rwkw @18psi
But I think I accidentally knocked the timing back a bit when I put my new timing cover on. Will check that and then see if it feels any better
Edited by 89CAL
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
