yea i think your right there, just putting cash aside now for t400 auto box and trans brake so im expecting to break diffs and axles more often when i get it all in the car. i found billet axles for my car rated to 1000hp for 550 delivered so if i break them again ill just upgrade. diffs i have just not axles.
Are they for Gts-t cause I only ever find GTR ones which I assume are longer?
Debating wether it's better to have the driveshafts as the weakpoint or not cause if I get stronger ones it's only gonna be something more expensive that will break instead......
Driveshafts should not break if the suspension is setup properly, the only other way they will break is fatigue from doing a million launches in them. If you have have really hard spring rates like 7-9kg/mm on the rear well that is way to hard, and if your car gets axle tramp when the wheels spin well that will also cause it to be weaker. Personally i don't know if GTR shafts are longer than GTS ones but i'm gonna guess and say they should be the same. If you are gonna be drag racing the car all the time then its probably worth spending some coin on the rear end suspension getting it right so when the car squats for a launch the driveshafts are as straight as possible. + dumping the clutch at 6000-7000rpm is not good either as this shock loads the whole drive train, in GTR's when you dump the clutch at 8000-9000rpm all the time i guarantee you will end up breaking something really quickly, need to side step the clutch by releasing the pedal slowly and letting the clutch grab slowly it might just save the drive train a bit of shock load. I see people all break shafts all the time, i've owned skylines and GTR's now for 6yrs + and have never broken a drive shaft yet and i thrash the shit out of my cars ask Kingy he can concur with this lol thumbsup.gif.
Haha yeah. I think my driveshaft that snapped was a bit of a random thing. Ask anyone I don't really do hard launches around town, I'm a girl and all that shit yeah yeah :P
But it's always in the back of my mind now, I'm mainly worried about if I ever get semis. But I need to slip the clutch a bit next time I go out for a run. The button clutch won't make it easy but I'll manage :)
cal, I did stacks of drags and launches and stuff, and with semi slicks and never had an axle problem. I think your problem was a bit of a fluke.
Also, always let the clutch out, never side step. Too much shock, and you'll only create unwanted wheelspin.
Does beat the shit out of it..... When its not parked up being worked on lol...:P
Ben, would t waste your time with the dirty thirty.
You're better off with the dirty whore, thirty four. Haha.
The rb30 cranks are a bit old to be spinning hard. The rb34 kit from spool has a billet crank in with the package. Costs $5k. Spin the f**ker to 10k and bolt twin gtx3071s on it, haha.
You need to set the record straight with the xr6ts ;)
Ah i got 2 RB30 blocks at home a shitty N/A block and a Turbo Block, should just sell them and spend it on my N1 engine or sell the lot and twin turbo the Z, hhmm never own 2 good cars it just makes it harder to figure out what to spend the money on.... someone buy my GTR i'm sick of looking at it.
the NA blocks are just as good as the turbo blocks (exactly the same) if they are a series 2 block. They have the oil and water lines for the turbo. Just bunged up.
I'd use one for the RB34 ;)
How long do you think Cals engine would last with the TO4Z on it? haha.
Lol Stock RB25 with T04Z = LAG MONSTER i'd give a week before it would blow a piston and rings to bits rolleyes.gif
I remember my mates R34 GTT i built for him with a GT3540 on a stock engine, damn that thing had bulk lag but was awesome fun on boost.
Seen an RB25 with a T04Z (all be it not as new design as the one you have) and yeah..... No thanks lol
The only reason I went HKS was for good mix of power and response, would have been more then happy with the Pro S. I'm sure of that
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
