I imagine the 350 will spool nicely lol
Yeah needed the ignitor bolts as the threads for it in the carbon coil cover were a size smaller for some reason. So just ordered some from pro bolt to check them out, good product :)
Will be ordering some new bolts for the spoiler end covers and a few more bits soon. Should look good
O.K so I've done some painting trialing out the colour I'm gonna paint a couple of things
Cam Cover:
Ignitor Bracket:
Think its a pretty good colour, just have to see if the paint sticks alright and finish prepping the rocker covers, should look much better then the ones on there now anyway
looks good Callan, never thought of painting the covers black.
Today was eventful. Tuned a RB25\30 with the GT3076, and Vipec. Fitted the boost solenoid, and configured all of the boost maps. The cool thing - The boost valve that Vipec sell as their own, is exactly the same as the Gizzmo boost control kit that I had in my R33.
Anyway, holds boost perfect, set it to 18psi, and configured all fuel to nice and safe.
Took a while to get the aircon idle settings happy but they are pretty close now. So many things to configure and get balanced out with the idle areas thats for sure. Might trawl a bit of the forum to see how others are having luck with it.
Now we're just waiting for the Digital knock kit to arrive, so we can fit and I can start cranking more timing into it. Also going to set up the knock maps so the ECU can pull some timing if there is any knock detected.
Lastly, there is a very advanced water meth kit being looked at, and then more timing if we get that fitted. I think he's going to wait until after xmas though.
Getting depressed - I need to start get another car and get into my own projects again.
But it was still a good day, its running beautifully and frying tyres easily, even with f**k al timing added. He's very happy.
Its evoke metallic, holden (VE) colour. looks really dark in the shade and sparkley grey in the sun. think it should look good :)
Ignitor bracket fitted. need to order more pretty bolts to:
Edited by 89CAL
yeah gonna see about some titanium blue bolts for the covers, but as long as my half moons turn up this week I'll put them on this weekend. Should look the goods.
Will paint the CAS soon, pulled my old one apart the other day, so I know how to do that now. The inner bearing was pretty wrecked, no wonder it was making all that noise lol
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
