umm if i was to put the turbo on the other side i would look like a f**kin dickhead..... and so do u for making that comment haha
annyyyy way. yeah ben i have worked on both too and everyone knows toyota's are built better / smarter in every way devil.gif
Well if it was a Nissan the turbo wouldnt be on the wrong side... But, I guess someone ie Toyota has gotta be different and homo and put the turbo on the wrong side... Lol
But I agree, the Toyota has a lot more thought put into it. Geared oil pump drive... 12x 14mm oil drains as opposed to 6 x 8mm drains etc.
Edited by The Mafia
Better built, but everyone loves an underdog lol
One of the reasons I never skid = axle tramp. Shook the sunroof controls from the roof it was that bad.
Hopefully will be getting much better launches when i head back out to the drags
Turbo landed in Australia during the week. Should have it an the wastegate by Tuesday. Bulk carbon parts from Phil, full kit, mags, internals, manifold is being fabricated at the moment. Got some HKS goodies as well.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
