  • 3 weeks later...
O.K I'm after opinions on oil pumps for my car
Keeping in mind its mainly street driven, although I would like to take it to the drags a bit more and maybe one day go for a few laps of Willobank
Pump options: Jun, N1 + Billet Gears, Trust/Greddy, Nitto, Standard with billet gears.
Oil control: Rear head drain only, Rear Head Drain + oil restrictors (size? dependant on pump as well I guess), or just oil restrictors
Theres to many different opinions and Ideas on here to decide so after peoples opinions.
I dont want to spend rediculous money, its not a race car, but at the same time I dont want to cheap out.
Spool Head drain kit plus Tomei Restrictors, and for the oil pump just get a Nitto pump a JUN one will be expensive and i don't think they make them anymore or that could be HKS can't remember.
Was the Trust/Greddy pump i saw cheap, the JUN wasnt to bad off nengun but then I gotta pay for it to get shipped over
http://www.kudosmotorsports.com/catalog/trust-greddy-oil-pump-trust-greddy-nissan-skyline-r32-gtr-r33-gtr-r34-gtr-rb26dett-p-1018.html
hey bud i've been living in mackay the last year now, just picked up my silver 350gt coupe 2 days ago from brissy and drove her all the way up here to home. Im nearly 100% sure its the only one in mackay, its also debadged so if you see me mate have a chat!
I finally got a chance to dyno tune my old setup, and fix up some issues with the previous tuners touch up. It only made 285rwkw before I fixed it up.
Once I got a hold of it, I fixed up the fuel and gave it a bit more timing. 4 degrees extra and it jumped 20rwkw.
Anyway, the torque was f**king awesome.
Ignore the drop off at the end - The straps on Clapos dyno are fairly buggered and the loosened towards the last 2-3 runs, and you could feel the car loosing load and dropping boost because of this. The earlier runs held the torque and boost to the limiter.
Anyway, here is the dyno plot. 820nm to the limiter feels very good under acceleration on the street. My mate is very happy with it.
Edited by The Mafia
  • 4 weeks later...
" mossy's " is the BP servo on the way to the harbour... i personally wouldnt hang out there lol
the drags are at palmyra which is out walkerston way.
their is a map here http://www.palmyradragway.com.au/aboutus.html
You just want to stay alpha dog in the p-plater crew haha
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
    • Yeah, Duncan is helping sell me back to Android devices. I've hated the whole Android head units due to their speed issues. Even in my old Hyundai Kona (2022 model), it behind the scenes was Android, and slow and shitty to start up. Once running wasn't bad, but still a good 15 to 30 seconds.
    • My roof rails are off atm on the E39 until the rust is fixed. I did find another little bit of surface rust under the rails when I took them off. As @soviet_merlin said I'd just leave them alone unless you're planning on ensuring they're properly sealed. I was on the fence about leaving them off as the delete is still a thing in BMW E39's but I feel like the car is missing something (er, it is, der) with them off and I'm looking forward to putting them back on.
