If mine dies I'll have a hard time deciding wether to switch or not. Buying a new PowerFC is easy. Plug it in, load my tune and away i go. But the added features of the Vipec are worth retuning.
Decision I hope I wont have to make for quite a while
Nah I didnt end up going, will sort out these boost issues and go next time KSOS and work dont line up
Next 1 is on the 20th Cal and im home for it. Pretty sure you are on the same roster to me?
Order the bushes and do it yourself I would not pay anyone to do anything in Mackay bunch of useless rip off merchants, I prefer to buy the tools I need and do it myself hate paying people to do shit.
I would have to find some sort of DIY guide because i'm in no way confident with something like this, but yeah i know what you mean!
If you don't want to do it yourself or take it to a shop, go and see Leon Minic, he'll do it for you, better than any shop and most likely half the price.
He's got quite a good set up too. He's one of the guys that runs the drift club.
Got any contact details mate and where's he from?
Press = hammer + socket lol
true, im going to have a chat to one of the boys from the workshop at my work and see if they have a press if not i can get a hand to do it DIY or talk to that Leon bloke and hopefully he has a press/can fix it for me cheap
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
